No, there was no test fitting prior to painting. I received the bumper, the painted it and on Tuesday they installed it.kyle@stillen wrote:Something doesn't look right there...
There is a little bit of a gap but that definitely looks like too much. You might check some of the mounting areas and make sure it was mounted properly. Did you or the shop do a test fit prior to painting?
I do agree that the middle is sagging just a tad and with me being OCD, I notice it big time! Aside from that, everything seems to line up perfectly. Like I said before, I'm going on vacation next Tuesday. I'm dropping off the car then and they will be shooting the paint to get it closer to the color and I will surely point out the sag. Luckily for me I haven't paid him yet. Hey Blake, can you take a close up pic like I did where the hood meets the fascia? I want to see if you have a gap too.adidas2go wrote:hmmm doesn't look like the gap is too much bigger than mine judging by my first posts pictures. Looks like the middle is sagging however. It fits perfect around the headlights so im sure the problem is just an improper contact point right in the middle there. I would take all the clips off around the top, pull the fascia up and make sure all the holes line up for the clips.
Thanks guys for all the compliments!
I was also pondering how the fascia would look painted all red with the exception of the grille and the bottom supports. Hey mcheddadi, can you photoshop that? just wanted to see how it would look. Thanks!
dangeris wrote:Man, you're fast! That's exactly what I was looking for except I forgot to say those little side fins need to be black also. I don't want to be a pain in the arse but do you think you can do the other pics as well so I can see how it would look from the different angles? Thanks in advance man!
Heres an idea. Open the hood. And look where the bumper touches the metal frame around the hood release? Lift up the bumper from the metal and see if the face lifts. If so maybe wedge something in between the bumper and the metal brace to keep it permanently lifted. I went and looked at mine and the gap has seals touching throughout with no real sag. I will take a pic tomorrow cause its night right now. Look at the pic below and you will see the area marked in yellow that you should try lifting.dangeris wrote:
zer...age=1pakicoupe wrote:hey adidas i'd appreciate it if u could get show some side shots of your coupe with the pro kit and tht fascia on a leveled surface.. i wanted to see how it looks lowered from side and u got the 1.5" drop all the way around correct?
Heres the shots i got. The close shot is of the area where you car is sagging. Mine doesn't seem to do it.dangeris wrote:
Nope, yours definitely doesn't. I'll make sure I point that out to them when I drop off the car next Tuesday. Thanks Blake for you time and efforsadidas2go wrote:
Im not sure of the exact amount. However this is what i remember. I stole these pics from another dudes thread since its night time here lol. Just use a screwdriver to pop off each of the clips. You can pry the screwdriver in the slot alloted and pry upwards. The middle will pop out and then you can grab it with you fingers and pull it out. If its tough use pliers to pull it out. To reinstall these just do the steps below in reverse order.dangeris wrote:Hey Blake, I had another question for you. Since you did your own install, I was hoping you can answer this question. Aside from the obvious clips on the top of the fascia, where are the other clips located? Is there any special trick to taking it off or putting it back on? Anything I should watch out for? how many persons are needed? etc... Thanks again man!
Thanks Mr_Coupe Question for ya...Did you have to leave your car at the shop or did you drop off the fascia to them to paint first then install?Mr_Coupe wrote:great job dangeris it looks awesome
Thanks Kyle! I appreciate the compliment! Stillen has been doing great things for us guys here on the forums. We really do appreciate it!kyle@stillen wrote:First off...Car looks great. We are all very excited and proud to see how well received these fascia's have been. We could not be happier about it.
Hmmmm...I think that is a mcheddadi question. If anyone can do that, mcheddadi can do it! Do your magic man!..do your magic!LongBeachCoupe wrote:I wonder what it would look in reverse... black car with red highlights
I don't know if you're considering this but if it were my car I would probably do something to match the nice lip on your rims.LongBeachCoupe wrote:I wonder what it would look in reverse... black car with red highlights
I should get mine from the body shop on monday.. then again I was supposed to get it friday and didnt. I just went with black/flat black. I decided to go ahead and paint the areas that everyone else is leaving unpainted. I didnt want to take the chances that the urethane would fade or anything so i had them painted a flat black. Oh, I also tinted the top half of the headlights while the bumper was off. Cant wait to see how it turned out!Caboose wrote: figured i'd jump on this cause ive been intreseted in seeing it with a black a/c.
