Hatchman wrote:1:When I have it plugged in and try to start it it starts then immedietly dies 2:When the MAFS is unplugged it revs up to 2500 and sounds like it hits the rev limiter3:Its an 89 240sx and I havent swapped in a 91-up tach yet4:My throttle body was chipped and I think the TPS was messed up so I got a new throttle body and my injectors were leaking so I put new o-rings in and swapped spark plugs cause the other ones were fouled by the leaky injectors
Oh yeah it starts up with the cold pipe dissconnected from the throttle body with the MAFS plugged up and it revs past 2500 rpms.
the reason it sounds like it has a rev limiter at 2500 rpm's is because the maf is unplugged.
this is a long shot, but did u check to make shure your tps is good?just check the voltage coming outa the white wire with everything hooked up. it should be .5 volts at idle and a little under 5 at w.o.t
also, check the signal coming out of the white wire on the maf with it plugged in. have some one help you and check the volts while you start the car. you should be able too get some kind of a reading even though your car will only run for a few seconds. im not shure what kind of voltage you should be getting from your maf offhand but you can easily find out
let us know what you find
