no spark in any cylinders could be because bad cas or wireing to cas...also if its not cracking over...pull your ecu apart and check to see if it looks like this....
zerothread?id=265103
if your ecu is fried...that would more then likely be because of your maf being wired wrong or the wires grounding out on themselfs...you can send your ecu to best1tuning.com and they have been able to repair the ecu's....
im thinking its fried ecu...
if not then the cas is installed wrong make sure you install it with the dots lined up...and check your knock sensor...
when i first got my blacktop....i had a bad knock sensor and only 3 plugs were sparking...pulled the cas out and put it back in and then none would fire...then once i got them to fire again my maf wires touched and grounded out and friend my ecu...the enging will turn over but it would crank..
and one more thing...check your fuse box there is a ign fuse that could also cause some of your problems...
let me know good luck
Modified by skaterfromvt at 3:56 PM 12/3/2008
