BuLLeTdrift »
https://forums.nicoclub.com/bulletdrift-u13321.html
Mon Nov 19, 2007 6:17 pm
show a pic of your CAS as it sits right there. sometimes it takes one full spin on the crank, other times it takes what seems like 1000 turns. also, pull the spark plug out of the first cyl and see if you can see the piston up high (not the tell all be all, but another thing to look for). you dont have to worry about bending a valve, you aren't messing with the sprokets themselves. the CAS tells the coil packs and injectors when to fire off, it doesn't tell the sprokets when to turn.
if you set in the CAS correctly the first time, and the weirdo who did the comp test put it back in as he found it, the mating mark should be lined up with the notch on the CAS. more pix
EDIT: ****, just noticed the CAS was out, thats changes it up doesn't it. nothing at all on the links? no distinct scratch, color, smell, taste? I can't imagine putting in the CAS at the wrong time doing anything too serious to the motor. Other than getting too much fuel in the system and just messing up your firing with spark and fuel order, but that can easily be reconginzed when it doesn't start.
More experienced owners need to show up!!
Modified by BuLLeTdrift at 9:00 PM 11/19/2007
