SR Dies out after a few seconds, help (searched, video inside)
White Comet
Car: fc, s13 and mazda6, Sierra
i agree, i wanna know what all it takes to fix
duffman1278
Car: 89 240sx Hatch, the wildcats!
Me too, I'm getting so anxious/upset I need to find out why now lol!
White Comet
well just replace everything /problem
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
White Comet
lol, any luck or havent worked on it anymore yet
duffman1278
Havn't worked on it yet, I can't install the fuel rail until I get those insulators. Plus I've been trying to study for finals, but if I get them tomorrow, I'll put it in
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
wait you have an after market fuel rail. or what. i am only changing my injectors and fpr
duffman1278
No, but what happened was that I took out one injector before starting it up because I found out one of them wasn't spraying(it is now, since I bought another injector) and when I pulled off the fuel rail, I didn't change the o-rings on the injectors because I didn't think it would be a big deal since I wasn't removing the rest of them. Well because of this, I believe that is whats causing my problem. I think its just that the fuel is leaking in. I've read it on other forums too, and some people have been having this same issue, just that no one updates their threads and says if they solved their problem or not, they just leave it dead, so I'm assuming when they changed their o-rings, it worked.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
aw i see, i hope you get it figured out, and did you get your timing bck on.
duffman1278
Yea, I went over it, put it TDC(or so I believe) with the markings where they need to be, pulley mark where it needs to be, the gold link on the bottom, and first 2 cams facing away from each other. So I'm just praying this will be it.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
pics man i need to compare.
White Comet
that could be the prob but unless its a really bad leak it wouldnt stop it from running
duffman1278
Well I got the last piece of replacement parts I needed so tomorrow I plan on installing them and letting you know. What pics do you need idaho?
White Comet
good luck, i'll be working on my car 2marrow 2, but mine already runs, so you know...............................
duffman1278
White Comet wrote:good luck, i'll be working on my car 2marrow 2, but mine already runs, so you know...............................
White Comet
im sorry i couldnt resist. i wasnt sure if u were gonna gimme the hammer bash smileys or if u were gonna go
duffman1278
Well after removing and putting on those stupid o-rings, and than dropping some on the floor through the stupid manifold, I put the injectors and fuel rail back in with the new o-rings, took out the fuel pump fuse, started up the car to burn off the excess fuel in the 2 cyclinders. Put the fuse back in and VIOLA! started upand stayed on, well I had to push the throttle to keep it on, but I think thats because its been sitting there for awhile. I could however hear a hissing noise from the exhaust side, sounded like air escaping, I'm thinking it could be the intercooler pipe that connects to the turbo?
White Comet
could be an exhaust leak as well. check both
duffman1278
Right now its just ends at the downpipe, sounds like a beast too omg
White Comet
oh well then yeah ur guess is right. i started mine up w/ just dp a few times b4 and yes it sounds like a beast
