No harm done. Especially since last time we raced, I was the one in front.HighPsiS13 wrote:Hey Spanish did you ever manage to get faster than that KA-t? lol. DD is a friend of mine for several years now im just poking fun at you man no harm intended.
OH SNAPPPPPP!!! Im going to have to call DD out on that one lol. Did he finally go sr or does he still have that garage full of 'expendable' KA's lol.spanishricer wrote:
http://www.youtube.com/watch?v=h1j5kIz63lM
But we both have new setups now, so perhaps some more summer fun in Mexico is in order?
Which manifold are you using again? Greddy, right?Solow240sx wrote:Im running the jgy fuel rail they fit great in the rain but wandering how there gonna seal to the intake manifold, they fit in the stock injector cushions but shouldnt there be another oring or way to seal them??
I'll have to get back with you tomorrow or Tuesday. Intake manifold is locked up with the car in the shop.Solow240sx wrote:Yeap im running the gready intake manifold...
I was running NGK BCP7RES plugs. I believe the part number has changed though, to 3330. They came pre-gapped, so I never had to touch them. If you need to gap yours, try .025. The plugs held 20psi fine last year, but I'm not sure how they will do with 30+psi.Solow240sx wrote:Hey man i got a couple questions for ya, what spark plug gap are u running, or were u running?? Im not sure where i should gap my plugs i got the ngks in heat range 8, Also where did you put your map sensor and how did u hook it up??
I'm not sure. I wasn't going to touch the wiring. My tuner is supposed to install the AEM and injector driver. Might want to check out the AEM forums.Solow240sx wrote: Also do u no where to wire both the ait and map sensor too im assuming the ecu but not sure where to at it..
I had the 3" 4-bolt outlet. Tough call on which housing to choose between, because I really don't know what plans you have for your car. The single scroll GT3076R will never be a "fast" spooling turbo on a 2.0L motor, no matter what housing you have on it. So I would go for peak power and the .82 a/r.kentuckyslider wrote:Quick question about your old setup. I just bought a GT30R with no turbine housing and I'm trying to decide between the .63 and the .82 ar. How did you like the .63 ar you had?? Which would you get betwwen the 2. Did you have a T31 2.5" outlet or strait GT 3" or Vband out? If you made 460whp at 20psi do you mind me asking what kind of dyno you were on and will you post the plot for me so I can see what to expect. Thanx
I'll be there, whether the car is ready or not. We're still trying to get everything for the E85 conversion together and installed, but the holiday weekend is making the parts take longer to get here. Very slim chance it will be tuned and ready by Saturday.Philipio wrote:Still coming to the dyno day this Saturday if your car's not ready Sean? Looks like you have a lot of last minute changes.
what wheel disk are you running in the frontsspanishricer wrote:Got rid of my 18" Work wheels and picked up a set of these:
17x9 +15 and 17x10 +20 SSR Professor SP1 wheels.
And with the tires that I hope will hold 600whp...
Mickey Thompson ET Street radials in 275/40/17.
I'm not sure of the exact difference including the tires, but with just the wheels, I was able to shave off 5lbs of unsprung weight per corner. The car handles, steers, and accelerates much crisper than when I was rolling with the Work wheels.
They don't look white as hot, but it was a sacrifice I was willing to make.
