Thanks, Me too! Your cooler will be better than nothing but it that way, it will definitively do something.rb25drag wrote:Ya I like the way yours sets, But I kept my bumper support.
The cooler sets right in front of my electric fan, So it should cool really well.
I have my oil temp gauge installed but I just havent ran a power wire yet. Im going to Friday. Hopefully I get a test drive this weekend!
This is from that link:"Both designs work on the "hot wire" principle. Here's how theywork. A constant voltage is applied to the heated film or heatedwire. This film or wire is positioned in the air stream or in an airflow sampling channel and is heated by the electrical current thatthe voltage produces. As air flows across it, it cools down. Theheated wire or film is a positive temperature coefficient (ptc) resistor."tight240 wrote:
I understand how it works, thats y i was trying figure out y it seems y people were puttin temp in as a facture.
Shocker wrote: I think 240sxmotoring lied about it being a "greddy" it says "GREX" on it....
Damnit!!!!!!!!!!!!!! there is always some politically right a** hole on here how come you cant just let me be wrong lol. Jus jokin, ok i see, i never got taught the specifics specifics, i was jus told it send a signal to the ecu sayin ey its colder air (more air molecules) go head and send some more fuel in here.rbsileighty wrote:
"Adjustments for air temperature and humidityare taken into consideration since they also affect the temperatureof the heated wire or film."
sorry I don't have a JDM company alternate name book at my disposal. No need to be a c***, I do believe Carl corrected me just fine. Thanks.S13Koop wrote:
rb25drag wrote:My solution I threw away my water temp senor and taped the hole for my Autometer water temp gauge and called it a day.
But I think over time the SAFC will help, prob not cure but help a rich/ lean motor with alot of street runs and tuning.
Whats the problem with removing it? It runs ALOT better now? I have only seen improvements on the things I have done.Carl H wrote:are you serious?you removed one of the major input sensors because you felt it wasnt needed?im sorry but thats effin rediculous...blaming the water temp sensor for a poor setup.
books? what the hell are those?guess u don't have the internet either i love NICO!!!Shocker wrote:
-Cory
oh you mean this: 7.80@91MPHrb25drag wrote:but yet when it comes to track times. I put down better numbers on my setup than anyone else that has a closer setup.
