Pros: no rust, no body damage, motor ran fine for the hour long drive home, hatch opens well, headlights work, got many extra suspension and brake parts with it (all the stuff off of his other 240), and most of the EGR system was already removed, and ALL the power options work (locks, windows and mirrors)
Cons: no a/c, only has at most 50% of the interior (and whats left isn't pretty), one coil is shot, exhaust is homemade, and the driver's door has a different lock (the key has to be wiggled around to open up everything else anyways cuz its so worn), the gas door has nothing actually holding it closed, the trunk latch cable isn't mounted so the handle doesnt open the hatch, all 4 speakers are in the car(only the passenger side front on works, the back 2 have the wires cut like 4 inches after the speaker)
BUT, overall, I am satisfied. Plans for now are to get it running reliably, fix up the interior a little bit, get some new coilovers, then save save save for the turbo and all the other goodies to go along with it.
This is the motor while its still in.
The air filter they put on (which happened to be put on wrong, the adapter plate was on upside down)
Tein Type HA coils, one is shot and they are completely unadjusted.
Spare parts.
Gauges that came in it, the oil and volts worked, water temp wasn't even hooked up.
Headunit that came with it. (its hooked up and works too =D)
Behind the front seat to the trunk is stripped.
Next post will have pics of the work we have done.
