SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sat Jul 05, 2003 10:45 am
A bit long winded, but I feel this article is worth quoting. This is a small bit from a test drive of an R32, R33, and R34 back to back to back, done for EVO magazine. Quotes come from issue#041, March '02. Shall we?
The author is speaking of a completely stock condition 1989 R32 on loan to the magazine from a Mr. Dave Redpath. Only mod being a "subtle Trust exhaust."
"....a thrilling wave of mid-range torque pushed my back into the seat. What was even more surprising was that the thrust continued, in fact increased, right up to our self-imposed 7000prm limit. This propensity to rev could be due partially to the freer-breathing Trust exhaust system, but the fact remains that this is still a seriously fast car.
On torrentially wet roads this Skyline had no problem breaking traction, both from rest and all the way around corners. In most other cars that might have been a worry, but in a GT-R it's merely the cue to keep your toe in and have fun.
On entering a bend, the Super-HICAS four-wheel-steer system resists understeer by steering the rear wheels initially in the opposite direction to the fronts, then latterly in parallel to help stabilise the car when it's settled into the corner. But the ATTESSA electronic torque split only diverts power to the front wheels when the rears slip, hence the need to keep power applied so the fronts can help to pull the car out of the slide.
This is the point where sceptics say 'where's the fun if the car does it all for you?' Answer is, it doesn't. You still have to apply the right amount of opposite lock at the right time and wind it off at the correct rate too, as well as re-learning how to use the throttle as described.
But forget how the R32 GT-R does what it does; how does it <feel> when it's doing it? In a word, fan-bloody-tastic! There's never been a better power-assisted steering system for feel and feedback than this one. Every nuance of grip and road suface is conveyed subtly and accurately through the rim and the slight initial understeer is telegraphed clearly, telling you that lateral grip limits have been exceeded. Provided the exit to the corner is clear, a slight squeeze of the throttle send the tail out in classic front-engined rear-drive fashion, but the way to gather it in is to counter-steer and give the throttle even more pressure. This transforms powerslides from silly, speed-wasting indulgence to, within reason, the fastest way to accelerate out of a corner.
The R32 does all this with the highest level of involvement; you are totally unaware of the technology, apart from the fact that you are grinning from ear to ear and accelerating away from corners that would be a sweat-soaked nightmare in lesser vehicles. It just feels like a perfectly balanced rear-wheel-drive car with uncanny traction. Unlikely as it sounds, this car feels pure."......
There you have it. Handling prowess to rival any car...and own most cars produced today...14 years later.
Please notice when the author states:"there has never been a better power-assisted steering system for feel and feedback." -this was a car built in 1989!
Skyline R32 GT-R > mr2
