sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Tue Mar 10, 2009 10:20 am
well im done..for now loli did everything but rebuild the rear caliper (which i think i need to do), and replace the tie rod boots. the oil filter was a PITA to get off (i have pics) but the Oil Filter sandwich is a good fit. all the gauges work good, fuel pressure is a little high (40psi), and the radiator leaks a little coolant (from drain plug, just going using stock radiator drain plug)
im VERY happy with the way everything turned out. when i first started it, it was blowing white smoke EVERYWHERE, but it was from the cold rainy weather. also, the oil pressure dipped a little from around 70psi on initial startup, to around 30psi after warmup..is this normal or should i be checking something? just want to be sure.
vac is still around 17 or 18..and oil temp got to around 125*F in a decent time. a/f ratio is much better (according to autometer phantom narrow band). but there was one thing i couldn't put my finger on..
there was a "rainbow" underneath my car after i moved it, like it was gas, but it doesn't smell like gas? all the lines are secured and the FPR and injectors are not leaking. it looked to be around where the fuel filter would be. what else causes rainbows on wet pavement other than gas?
other than that, its PERFECT. it boost good, but i went nowhere fast due to wet pavement..i just have to do the radiator thing, and get all the air out of the cooling system as it started to overheat just sitting there..so im guessing its an air pocket. no leaks from any of the turbo lines as of yet either, but i will keep a close eye on everything this next month before i take it to the track. pics and a vid coming in a little bit..i have to go eat..im very hungry
