I'm assuming it will be enough AFTER i upgrade the stock battery and wires, correct?rjdmmfl1 wrote:...I would say, for your setup, something like the KINETIK HC800 power cell would be more than enough to keep the proper voltage going to your amplifiers, and give you the power you need!
Yup. It takes some work with the OEM fused distribution block, but I believe the 1800 is the largest Kinetik battery that will fit there. I think Doc at one point posted some pics of how he got his in there.dangeris wrote:Thanks Apple and Doc. I appreciate your input on this. No Caps it then.
Apple, when you said an HC1800 will fit the stock location, are you referring to replacing the stock battery with a Kinetik HC1800? I'm assuming yes but just wanted to clarify.
Thanks Apple. That's going to help out a lot! So what's the difference between an Optima redtop battery and the kenetic? Aside from the obvious, like CA, is that the only reason to upgrade to a Ninetik batteryAppleBonker wrote:
Ah, yes. Here it is
On the Kinetik side, if the price is about the same, I would recommend that route. I've been happy with Kinetik and I believe Doc has as well.dangeris wrote:bump
Also,..where's a good grounding point for the amp? Should I use the bolt that holds down the stock BOSE amp?
But when I pulled off the connectors, this is what I see. I was able to find the grey/violet tracer and white/blue tracer but there were two sets of Violet and light green wires. I'm assuming the pair of wires directly below is the right rear positive and negative. The pair directly on to the left of it, I'm assuming is the front speaker wires but the color code that Doc gave doesn't match up to what I see. As you can see below, the wires a black w/ red tracer and white w/ red tracer while Doc gave Black and White. The left Doc mentioned it was red and green but as you can see it's the same color as the right rear, violet and light green.rjdmmfl1 wrote:OK, this covers the entire thing, if you have the BOSE SYSTEM...
**note** this applies to the wires leaving the BOSE AMP going to the actual speakers... so these are post BOSE AMP...
KEY Right = passenger's sideLeft = Driver's Side
Front Right Tweeter + Blue/OrangeFront Right Tweeter - Green/Blue
Front Left Tweeter + LightgreenFront Left Tweeter - Black/Yellow
Center + Black/PinkCenter - Orange/Black
Front Right Door Speaker (6.5") + Green/WhiteFront Right Door SPeaker (6.5") - Brown
Front Left Door Speaker (6.5")+ WhiteFront Left Door Speaker (6.5")- Black
Rear Right Woofer (6x9) + Brown/WhiteRear Right Woofer (6x9) - BRown
Rear Left Woofer (6x9) + White/BlackRear Left Woofer (6x9) - Green/Black
Rear Right Tweeter + BlueRear Right Tweeter - Black/White
Rear Left Tweeter + BRown/BlackRear Left Tweeter - Red/Green
OK, here's the colors of the wires PRE BOSE AMP.. these are the wires you want to tap into if you want to add a high lo converter BEFORE the signal reaches the BOSE amp...
AMP ON - Black/PinkBAT - Yellow/RedSPEED SIGNAL - Violet / WHiteGround - Blue / BlackACC - Violet / Yellow
Left Front + GreenLeft Front - Red
Right Front + BlackRight Front - White
Left Rear + GR\rey/VioletLeft Rear - White/Blue
Right Rear + VioletRight Rear - Lightgreen
Always on? that can't be good. doesn't that drain your battery?LittleMan wrote:... i run all 4g wire with a cap cuz i need the 13.5 power out cuz of my amp. my stock alt is only doing 110 at 12.... My cap is ALWAYS on even when my engine is off; its the main power for my car.
That would be great Doc! I tried hooking everything up today and the amp doesn't turn on. Funny thing is when I take a voltage meter to the and test it, I get 13.5V at the power, and 11.5 at the remote...but still nothing. Could be a bad ground. I used the bolt that was holding down the Bose amp. Maybe not a good site. Gonna tear everything out tomorrow and try again. Maybe try to get to the wire at the cig lighter. I don't know...too tired right now to even think about it. Just got back in from trick or treating with the kids...I know, it's not Halloween yet..don't ask..rjdmmfl1 wrote:DANGERIS,
I'm just seeing this thread... here's the thing..... the wires going into the amp are a bit different... that's because they pass a number of connections after they leave the head unit... the colors I gave for pre Bose Amp are the wire colors at the factory wiring harness up by the stereo... but again, by the time they get to the amp, they have passed a number of connections, and the colors change (i mentioned this in another thread and i have NO IDEA why nissan does this... if you want, i can check the FSM and get you the wire colors at the point of connection to the Bose Amp!
Where is this connector? Is this behind the glove box?rjdmmfl1 wrote:DANGERIS,... the colors I gave for pre Bose Amp are the wire colors at the factory wiring harness up by the stereo...
No, he's talking about the harness that plugs directly into the OEM head unit. Basically the wires that come directly out of the stereo. I'll try to check the service manual tomorrow at work to verify colors for you if Doc doesn't get to it.dangeris wrote:
No, there's about 10 connections between the beginning of the harness and those brown harnesses that plug into the Bose Ampdangeris wrote:Understood Apple but in opekone_1988 post http://forums.altimas.org/zerothread?id=325092, the 4th picture down shows the purple/yellow wire. Looks like the connector was located behind the glove box ...
Doc wins on the looking at the manual race.dangeris wrote:BTW.. What's the difference between AMP ON and the ACC? Since you posted the wire for the battery, wouldn't these be same as remote?
Yup Just checked that I get Zero when I put one probe to the bolt where the ground is and the other probe to a near by bolt, or to the body itself, and to the distant end of the ground wire. They all read Zero. I even tried it buy putting the one probe to the near by bolt and touching the other parts that I mentioned. All Zero! It's gotta be a bad amp. what do you guys think?AppleBonker wrote:Did you verify conductivity to ground? You've obviously got power and the turn on should be good, so I'm concerned about the ground. Use your multimeter and check the resistivity from the ground terminal on the amp to the body of the car (it should read zero). This should be your first step. Let's make sure we can get the amp turned on.
I think i would just run the wires from front to back, and use the color scheme on the factory harness up by the radio.... for the record, nissan sucks for its ridiculous color schemed wires!dangeris wrote:
