WOW!!! What a great dad ! RP is the best ! I would drain little by little untill it is at level. Then check to make sure your not over boosting. Taking off the boost control solenoid wont hurt. It might even get you 10psi. A boost gauge is very helpfull and will tell you how much boost/ vac you have. Report back after completing.Team_Undisputed wrote:he used Royal Purple oil 10W-30
Rosco wrote:I bet it's an exhaust leak where the manifold meets the turbo....
alright man thanks for the help ill do it tomarrow its pretty late to do it over here so ill just do it tomarrow after schoolheres a pic of the dip stick when i took it out today:(the red H is where the dipstick has the "H" engraved on it and the green line is where my oil level is at )supreamS14 wrote: WOW!!! What a great dad ! RP is the best ! I would drain little by little untill it is at level. Then check to make sure your not over boosting. Taking off the boost control solenoid wont hurt. It might even get you 10psi. A boost gauge is very helpfull and will tell you how much boost/ vac you have. Report back after completing.
alright ill look into that too but the manifold seems to still be in tact with all the bolts no gaps except for this one in the pic ( the red circle is where the bolt seems to be missing?? and the red lines is where there is a tiny gap but im not sure that there is supposed to be a stud there)Rosco wrote:I bet it's an exhaust leak where the manifold meets the turbo....
alright thanks for the help man so how should i try to close up the leak check for the rest of the studs??FlatBlackIan wrote:There should not be a bolt there, that is the back of the stud, there is a nut on the other side of the turbo's flange.
The gap you are seeing is where the gasket is. It only takes a tiny leak to create a hell of a squeal under boost.
Check the tightness of all the nuts, they tend to come loose, its a common problem.Team_Undisputed wrote:
alright thanks man so i was driving my car today now that the oil was lowered and no it seems to bog a little bit more when i push it in first the car struggles and i hear some sort of a backfire coming from the exhaust and then it just pulls probley spark plugs??(they were changed the night before same time as the oil) so im like what the heck is going on now lol and the turbo is still screeching oh and when i got out and popped the hood the turbo and manifold were bright red....cause of the heat??? or something else?FlatBlackIan wrote:
If you cant get rid of the noise by tightening them, you will need to replace the gasket.
alright sounds good i was about to clean my MAF anyways so i might as well lol oh man i really hope its not the wheels hitting the housingssupreamS14 wrote:My exhaust mani and turbine glow bright red only after drifting and boosting for a few minutes. Did you gap the plugs correctly? my car would bog when my maf was dirty. I used some crc maf cleaner and it pepped back up. when the motor is cool you could put some soapy watter by the turbo gasket and rev it to see if there is bubbles indicating a leak. This might not work considering things expand as they heat up.
I don't want to say it but worse case mabby the turbo wheels might be contacting the housings.
thatnks man your a life saver!!!FlatBlackIan wrote:If you have glowing red exhaust parts, it is likely you are running lean. The only time you should see that sort of heat, is after extended bouts of boost.
The backfiring lends credit to that as well. I would check for leaks after your MAFS, before your turbo. Also check for ECU codes.
Id put money on the gasket being toast, Ive heard that noise before. It looks like you will be pulling the manifold and or turbo to replace it.Team_Undisputed wrote:video of the noise is up
alright thought so thanks for the help man do you think i could go a drift event like this and then change it afterwards or will it just make it worse?? and can this be causing my turbo to be laggy??FlatBlackIan wrote:
It will make the car a little laggy, but I dont see it causing any serious problems. I would be careful just in case, keep an eye on your gauges. If you see the manifold glowing again, I would be careful, you may have other issues.Team_Undisputed wrote:
Apparently your ability to read died along with it.ryanmasters240 wrote:this happened to my buddys ae86 and it killed his oil pump
FlatBlackIan your a life saver man thanks so much for all your help man!! i just added some silicone high temp gasket maker to it just for the mean time to see what happens and then change it out later hope it doesnt make more problems....FlatBlackIan wrote:
i dont have anything that can check for codes all it does is it sputters and adds no boost and all these popping noises come from the exhaust like its backfiring but not as loudFlatBlackIan wrote:Any ECU codes?
its a S13 redtop 1st gen?? i added silicone around my manifold and where the turbo go so it could seal it up a little bit and now it wont even boost.. man im really bummed right now i mean really bummed....FlatBlackIan wrote:
What gen SR?
You should be able to pull codes directly from the computer, using the OBD system.
Neil is correct, It sounds like a boost leak, go over all of your charge pipes.Team_Undisputed wrote:
