Yeah we're going to try it with the stock injectors. If it leans out too bad then we'll switch them up.adidas2go wrote:The stock computer tune on the v6 is good on the wideband for a/f ratio up to 5 psi. Makes me wonder what the stock injectors would do on the 4 cyl turbo.
Here's what you have to do for the oil pan (upper oil pan as the lower one gives u no space to tap):
Not my pics:
Now depending on the fitting you may not have to tap that big. Also finding a tap in this size is difficult. My fittings i belIeve are press/push fittings so i just need to drill out the hole to the right size and pop them in/JB weld them up. Going to check that tomorrow. Car will be down putting everything on until Tuesday... Dad doesn't know he's driving me to work Friday, Saturday and Monday hahaha
