s13 - rb25 + 383 + boost = MATAfied's ride
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
thanks for all the support guys
well here is a pic of my mesurements i used when fabing up my mounts dont know if it will help you. also note the depth of the pan at 4 inches to clear steering rack.with this the passinger side motor mount would be 2 1/2" and driver side would be 2 "
i still need to clean this up lol
i am using a small cap HEI distributor
Modified by matafied at 8:46 PM 12/29/2008
xX-NISSAN77-Xx
nice!! great work.
dblanehopr
Car: 93 primed black fastback
freakin sweet man. thanx.
what all did you have to do to the crossmember.
it doesn't look like you had to do much. someone was saying you have to cut out some on the front side. didn't look like you had to.
and what type of mounts are those? are those just the 240 mounts?
i'm trying to remember what the crossmember looks like stock, it's been a while. i can go take a look at mine though. are those the stock mounts or did you have to weld those in?
btw: hope you don't mind.. i'm gonna have to save these pics for reference later. ;] i've had plenty of lessons in the school of hard knocks, it's okay to take cues now and then... gets you by better when you've only got one shot to make it right.
again, i really really appreciate this thread, brother. thanx
matafied
Well I did not even touch the cross member (its a R33), not even to clean it lol. Also the mounts are solid rubber and I used it to just figure out the height. I will be making some new ones when it’s all ironed out. I would have had it all done yesterday but my brother in laws rb trans was acting up and had to rip it out.
dblanehopr
ah no kidding. so the oil pan you made was made just for the r33 crossmember? or is the r33's similar enough to the 240's?
i've heard that a NovaII's oilpan fits the 240 crossmember.
nice heated garage btw.
USsil80
matafied wrote:Well I did not even touch the cross member (its a R33), not even to clean it lol. Also the mounts are solid rubber and I used it to just figure out the height. I will be making some new ones when it’s all ironed out. I would have had it all done yesterday but my brother in laws rb trans was acting up and had to rip it out.
nice build man... but i still see a fmic.. you get crazy ideas with a FI SBC...
looks good
matafied
oh yea, got to have some boost
dblanehopr
dblanehopr wrote:so the oil pan you made was made just for the r33 crossmember? or is the r33's similar enough to the 240's?
tryin to get a good gauge on the oil pan and mount and crossmember section before i start the project. gonna have to getrdon. would the oilpan set up you made work right demensions on the 240's crossmember too? and you were saying those mounts are R33 mounts?
WDRacing
R33 corssmembers are different the S13/S14 crossmembers, so his pan won't fit yours.
The NovaII pan will work though.
Are you going with a single turbo setup? I thinks a set of twins would LOOK awsome, albeit complicate everything.
WD
matafied
yea i was thinking about twins, but just want to keep it simple right now <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/hide.gif" BORDER="0">
Modified by matafied at 6:18 AM 4/9/2010
dblanehopr
WDRacing wrote:R33 corssmembers are different the S13/S14 crossmembers, so his pan won't fit yours.
WD
that's what i heard bro.. was hoping for more of an intial setup that i could not fully run off of, but know that that setup fits and i only have to worry about fine tuning it.
so... a 240 crossmember.. and a 350 w/ a Nova II will fit after makin some mounts... yeah?
Matified, be nice for you to go Forced Induction so you can mess with the Air/Fuel lil more.
matafied
dblanehopr wrote:so... a 240 crossmember.. and a 350 w/ a Nova II will fit after makin some mounts... yeah? .
i have a question about that, Has anyone seen this done? i have heard the chevy II stuff but never seen it used on a car, everyone still ended up makeing a custom oil pan.
also one other thing to keep in mind is the stroke, 350 work's fine with chevy II stuff ( i.e. sump, and pan ) but when you stroke the motor (383) crank hit's the sump. so just another reason for me making my own
dblanehopr
might be easier to make one anyways cuz you gotta find the NovaII pan first before you can do it. might be able to.. dunno.
all the measurements you made for that pan was just made for the R33 crossmember then.. meh.. i'll just have to do it meself. ;] mize well.
tryin to remember... the slope of the engine should be 15 degrees right? i'll have to look that up again.
matafied
this is another reason i went this route, factory s13 transmission crossmember with a 92 camaro transmission rubber mount. Drilled one hole
WDRacing
Sweeet tits dude!!!
Not fabbing stuff vs drilling a hole FTMFW
Also, I didn't know you needed a new pan when you stroke the 350. That complicates the turbo 383 S14 I'd love to someday. Perhaps a simple high compression 383 will be easier...
WD
matafied
WDRacing wrote:Also, I didn't know you needed a new pan when you stroke the 350. That complicates the turbo 383 S14 I'd love to someday. Perhaps a simple high compression 383 will be easier...
WD
in a normal application the stock 350 stuff works fine, but in a 240sx with front sump you run into problems. The stroke is bigger on a 383, meaning the crankshaft is bigger. with the chevy II sump assembly the rod cap bolts hit the oil pickup tube.
dblanehopr
but with the right pan you don't have to cut out the firewall using a 240's crossmember?
matafied
alittle update, have had little time the last couple weeks to do muchi have a lot of cleaning to do hahah
matafied
well a little late to start on this engine bay, but better now than never.I dont have any clue why i didnt do this before i put the engine in
motoman399
Car: 98' wrecked (RHD coming soon) 240
im really glad i came across this build. its pretty awesome even for a chev motor lol keep it up
matafied
thanks, finishing up the engine bay. looking good
matafied
man i cant wait to drive this thing, i still have butt loads of work. but i am making progress
Neejay
Subscribed. Anymore updates???
matafied
well haha i have turned direction with the setup, i wanted a more universial setup for when i really build the motor. i changed the heads and intake combo. 64cc aluminum heads with edelbrock efi intake, fuel rails and high Flow elbow. Which works with ls1 throttle bodys. added a little eye candy some P45r's 18 x 9.5 +20 all around, dumped the tein ss as low as they will go, and rolled the rear fenders.
let me know what you think
Modified by matafied at 3:58 AM 3/17/2009
Modified by matafied at 3:59 AM 3/17/2009
Modified by matafied at 4:01 AM 3/17/2009
matafied
540sx
Car: Nissan 240SX
nice build. like the oil pan. what kind of heads? obviously aluminum guess the 64cc heads me no longer going turbo? did you upgrade any of the bottom end of the motor?what kind of power you looking at, that intake should move lots of air.
matafied
450SX! wrote:nice build. like the oil pan. what kind of heads?
thanks, the heads are cheaper pro comps with manley ss valves and comp cam springs, MLS head gaskets and ARP Head bolts
450SX! wrote:guess the 64cc heads me no longer going turbo?
haha yea well, i still want boost even if its only 7 pounds, water injection if needed
450SX! wrote:did you upgrade any of the bottom end of the motor?what kind of power you looking at, that intake should move lots of air.
yea bottom end is pretty stock it has been rebuilt and bored ( 355), not sure what this thing will put down or how long it will last.i just wanted to get everything made and get my setup in stone for my 383 short block im working on
i just knew the tpi wouldnt flow enough for my 383
540sx
Car: Nissan 240SX
after reading this last night I looked in summit racing's catalogand saw some keith black hyperpeutic pistons that are -13cc with a 9.0 comp on 64cc heads. I would use the forgedaluminum over the hyperpeutic from what I have heard but , guess you can get a pretty low comp ratio with 64cc heads. on my motor the engine builders also used a thicker gasket ,I think it was a cometic head gasket. to help lower the comp ratio as well.
wrxratd
Car: 1990 240sx hatch, 2002 WRX
Who cares about c/r!!!
Just use some water/meth injection and e85. I'l bet at 9.0:1 with water/meth and e85 you'd still safely be able to run 18 psi... at least!!!
matafied
wrxratd wrote:Who cares about c/r!!!
oh yea! we will see
Return to “Hybrids”
