WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Mar 24, 2009 3:18 am
Well, that only "kinda" works when your actually on boost. Because the only time it's actually pulling air when the old turbo is spooled up. When she's not spooled there isn't any vacuum there. If there was vacuum then you'd have a serious restriction in the air filter...lol. Unfortunately, the amount of blow-by usually caused when at full load on boost is more then what will be able to be pulled out via pre-turbo suction.
Granted, it does work better then nothing. But f you use this method, I'd also tap a vacuum source from the manifold so you have evac during off boost driving.
Another thing you can do is use a GM vacuum pump. They came on tons of vehicles, from cars to trucks. They can be had for like $20 from the JY. Easy to wire up and you're not pulling fumes into the intake tract at all. This combined with a header mounted setup would be the best bet IMO. OR, have the pump triggered via Hobbs switch for on boost and use manifold vacuum for off boost. Basically any combination of the above idea's...lol.
When I finally finish a project I'll do a couple different write-ups on the different things and what works best. But you'll be done way before I will. So you're the guinea pig
