Fenris wrote:krash wrote:
are we talking calipers or rotors here...?
Yes
Once the wheel is locked, which stock brakes can do, how does having a bigger brake matter?
The only thing that slows you down, is the friction of the tire on road. (or air brakes or parachutes)
The maximum way to induce friction in theory is to lock them. Granted control wouldn't be that great in that situation.
So, granted, bigger, more pot brakes could lock them faster, but stocks will do the same just as easily.
The big difference is that bbk rotors can vent heat better, and bigger rotors need bigger calipers. Less heat is less fade.
Not entirely true. Locking the brakes locks the tire, and a locked tire will not slow down a car nearly as fast as using maximum tire adhesion.
Bigger brakes allow more control over the braking force, allowing you to better modulate brake torque.
Also, with the right tires, locking up stock S13 brakes can be nearly impossible.
Its really a moot point thought. If you are dragging legally, then there is plenty of run down room, and huge brakes are not necessary. Its only if you are a retard street racer that you worry about something like that.
In truth, drum brakes are actually better for drag racing. If you are power braking with disc brakes, the force placed on the pad can actually hang it up, seriously hurting 60 ft times. Drum brakes release in a different way, negating this issue.
And remember, when you dont need them, every ounce counts, big a** brake rotors are heavy.
