Red & amber are genuine superflux. White are HKB.Redevil wrote:Wow you really went over board with the number of led's you used. Did you use real sf or bk's. How many ma's are you running them at? I used 40 in my 3rd brake light and that was a little too much.
Also they sell silver perf boards at fry's.
Nice job, man. Have you thought about doing something like this?Back door access!!!Dammitboy wrote:The difficult thing about this is removing the lenses. I hate to say I've ruined 2 sets so far. The problem is the red & amber lenses wrap around the housing & like to break easily, or if you use too much heat, you'll warp the lenses also.
Anyone have suggestions?
You gotta tell us how.Dammitboy wrote:I found a better way to remove the lenses recently, so the project continues!
What I wanted to do was fill up as much space as possible, & I did not want hot spots the way incandescent bulbs give. Plus the corner that wraps around has light now wheras before there was very little.1unar3clipse wrote:How did you decide the array numbers? based on resistance requirements or by aiming for an OEM filled look about it visually?
sickDammitboy wrote:Made a daylight video, I'll post a night time vid later.
http://www.youtube.com/watch?v=443GuPKhXlo
i think im going to try this in my s14 center section. if it turns out nice ill continue to the outers. thanks for the ideas guys94_240sx wrote:
Nah, that's just an artifact from the camera capture. Pictures don't do these things justice, They are retardedly bright!dontuhatepants wrote: Do they flicker? It looks like they are in the video but it might be the camera.
