OK, here's a write-up on how to do this thing, which I'll never do again. Honestly, this is an expensive, time consuming, frustrating mod, so do it at your own leisure, & your risk. I'm not responsible! First, get ahold of a SPARE SET of tails, remove the tabs with a Dremel tool. Don't have one? Get one!Bake lenses at 175 degrees for 1 hour.
Starting with the reverse lens, carefully put pressure through the bulb opening to remove lenses. Extreme care should be shown to the red lens!
At this point get your dremel...
And your Perf board...
Trace the perf board to the shape of the housing you want it to go in & cut it out with your Dremel.
Repeat these steps for the other sections.
At this point, you can arrange your LED's the way you want them, but I highly recommend you read up on LED arrays, & understand the concepts involved.
http://www.hidplanet.com is a great place to start.
From the back, solder your joints accordingly to fit your array's needs.
All for now, will finish up later.
Here's a few still shots.
Modified by Dammitboy at 5:56 PM 1/2/2009
Modified by Dammitboy at 5:57 PM 1/2/2009
Modified by Dammitboy at 6:01 PM 1/2/2009
