s13lover1 wrote:Funds are not that great for this month so havent got much accomplished accept for the wiring which was pretty easy. Also I have been pretty busy with enlisting for the marines. So hopefully I should have the engine and the majority of the parts by early of next month and have it completed before the end of the month.
Hey i think its cool your doing this on your own but i should warn you man, parts are not cheap.
The motor is pretty inexpensive but the headers unless you make your own are 900 bucks. The adapter plate for the VG trans is like 300+ Then there is the shifter position bracket if you want to use stock cut out for shifter, Bracket for alternator relocation, flywheel spacer, driveshaft, egr block off, block off vg starter, oil filter reloation if you dont want to notch the frame.
Im not saying it isnt possible, its just alot of work and money on parts alone.
If your dead set on it, Good luck man.
