You would need all the wires that come out of the ecu. There will be a few more wires and plugs separate from the engine loom and thats all. You don't need anything pass those plugs.red24d wrote:Alright, I've been searching high and low to find the info needed but just can't seem to find the right place. Since you are coming from the same place I am with a donor car, can you specify what all parts of the wiring harness is need from the Q45? I was reading something about under the dash in another thread and still didn't get the answer I was looking for. And FYI, I am aware that the ECU is under the dash, pretty sure it's on the passenger side kick panel, just not sure if more wiring other than those going to that is what was being talked about.
