When my project gets underway I'll be sure to give you a call. I'm all about reflashing. We had to socket my Skyline ECU a few years ago, worked very well. I'll be in touch...Mettler wrote:You should consider modding the factory ECU, I can arrange doing this for you. It's more powerful than an aftermarket job !
With a little narrowing of the diameter, the inner spring shim from the intake side of a VG30 will work. The VG30E inner spring is wider, but the shim has the same clearance on the guide as it does with the VG30E.Ezekial wrote:
I am now just waiting on 7 conrod bolts. 9 arrived instead of 16. And the inner valve spring seats
thanks mate!defrag010 wrote:With a little narrowing of the diameter, the inner spring shim from the intake side of a VG30 will work. The VG30E inner spring is wider, but the shim has the same clearance on the guide as it does with the VG30E.
was just under eleventy billion dollars so i think i did okskylndrftr wrote:soundign freaking awesome...
definitely good choice on the ECu...gonna be worth the eleventy billion dollars they charged you are you planning to use the anti lag and tc?
When I was looking for an ecu, the microtech couldn't even do 8 cyl's sequential injection and 8 ignition drives. The linkPlus was easy to program and did the bizzo...also the guys are helpful and great to deal with.Ezekial wrote:LINK ecu's are garbage
We do a regrind to ~264 9.5mm lift.Avail of cam billets is reason for not having replacments. Cost is prohibative.PoorManQ45 wrote:The members here have been unable to find an aftermarket company that sells cams for the VH45DE. The main problem that you are going to run into is the VVT (Variable Valve Timing). A regrind of the factory cams would be a wise choice..
I'm pretty shure you can swap a biki daughter board onto those particular ecu motherboards.Mettler wrote:Yep... any factory 28pin Nissan EEPROM (and other manufacturers with 28pin eeprom chips for that matter) can be modded.
I've got a VH41DE and I'm gonna socket & mod my EEPROM as soon as my car is together.
well sorry to say but look at your market. people with too much money and no idea. this is NOT an insult by any means. its just the truth.skycat wrote:Well sorry to say at our shop we wont even look at a car fitted with a microtec, heltech or wolf these are all greif and not worth our time,
how does it run.... street tyred, pump fuel, stock turbos no gas and it ran 11.2 at 121. The car is not the sort to be compared with as Dales car runs slicks, C16, nitrous and a big single. Our S14 will need some sorting but it will go fast soon. The owner of the car doesnt want to get booted fom WSID just yet so isnt fussed that it hasnt run that magic 9 second pass. Does Dale know exactly how much power this car makes??? i hear he isnt even able to strap it to the dyno properly to get an accurate figure??? we know exactly how much power our S14 makes and let me tell you, Dale is a little behind the 8 ball!!!Ezekial wrote:well sorry to say but look at your market. people with too much money and no idea. this is NOT an insult by any means. its just the truth.
i am yet to see any advan cars run quick times in comparison to what cars with microtechs run. how does that s14 run compared to say ... dale's rb30/25 one with the microtech? but hey you are preaching to the converted. I have an M800
OR you can keep it simple & just socket your eeprom, run the romulator & tune the ECU how you like, then chuck a burnt chip back into it.Bigvinnie wrote:
