JimmyMethod wrote:That's intense.
yes. i scrapped the twins and now have a GT42RS 53 trim 1000 hp turbo.
It fits nicely in the drivers side (RHD vehicle) nicely ... just behind the headlight ... no real room for a filter though given the 5" inlet
Quote »What do you do for mounts, are you fabbing them? How hard has this been so far? Do you see any problems with left hand drive? If this isn't too rough, then I will sell my S13 and get an S12.[/quote]How hard? Not very!
Mounts are fabricated yes ... easiest being the gearbox mount which is a cut and shut infinit s12 job ...
Also ... the steering rack is really the only issue ... and lack of room for power steering pump, alternator, etc ... alternator had to be moved on top of the engine like on the VH41's ...
There is quite alot of room for exhaust manifolds to run across to behind the right hand side headlight ... the standard auto fits in the tunnel ...
what else? the heater has to be removed and new lines run ...
the wiring from the right hand side inner guard has to be completely removed and re-run around to the left or some left inside the car in my case ... otherwise the exhaust will fry it ... it will run through the inner guard ... this is for big single turbo
I believe there is a bit more room in S13's though ... i didnt want the extra weight though ... or the IRS
