Buying the parts on your own and then bringing them in for a mechanic to install is insulting. He makes more money off the parts, that's half his business.Innovazn wrote:when i had my brakes done, i got all the parts on my own.... the rotors i got were above OEM grade and only costed me 50 bucks a piece. the next time i redo my brakes id be pushing a bit more for better rotors and pads.
it was my old training academy that did the work... they dont make money off parts regardless.Empty V wrote:Buying the parts on your own and then bringing them in for a mechanic to install is insulting. He makes more money off the parts, that's half his business.Innovazn wrote:when i had my brakes done, i got all the parts on my own.... the rotors i got were above OEM grade and only costed me 50 bucks a piece. the next time i redo my brakes id be pushing a bit more for better rotors and pads.
warping doesnt concern you does it...Chuck Tribolet wrote:If the pads didn't wear to bare metal and the rotors are within thickness spec, there's no need to do anything to the rotors.
I'm on my fourth (I think, maybe third) set of Nissan pads, 186,000 miles, original rotors. And about a third of the miles are towing a 2000
pound boat trailer.
Chuck
What is warping?Innovazn wrote:warping doesnt concern you does it...
WarpingEmpty V wrote:What is warping?Innovazn wrote:warping doesnt concern you does it...
So how does a brake rotor become warped?Innovazn wrote:Warping
1 ) to bend or twist out of shape, esp. from a straight or flat form
2 ) a hypothetical means of propulsion also called a "warp drive"
3 ) the faster-than-light movement in science fiction, as used in Star Trek
take your pick
when i first got my truck, my front rotors were warped. and let me say before you ask, no i dont have a warp drive hooked up to my truck nor was i in the science fiction show call Star Trek either. Whenever i braked i would literally feel the pedal pulsating following the bend of the rotors. not fun.
hard braking is a factor as well!! (of course generally when rotors are roasting hot)GoldenR50 wrote:There are several causes for warped rotors. It can result from normal wearing of the rotors. It will often occur if you let the brake pads wear to the point where is there is metal-to-metal contact between pads, or what's left of them, and the rotor. Thus, the importance of routine brake pad inspections. Warping can occur if the brakes are very hot after a long trip, or many applications, and then the vehicle is driven through a puddle of cool water.
Read my 2nd sentencefueler wrote:lol i love how yesterday youre like "what is warping" and all of a sudden today you're the resident brake expert
brakes DO warp, obviously youve never dealt with it
some experts say its not the metal bending but rather a buildup of pad material on the rotor
i dont care what it is, brakes warp all the time and thats why every brake shop has a brake lathe. If brakes dont "warp" then please explain the reasoning behind resurfacing rotors every time pads are replaced. Maybe resurfacing rotors is a giant "myth"
lol
I can tell you definetely are one of those guys that make up explanations and such on what makes sence in there head, or you think its right so it must be right , you can turn rotors more true then they came from the factory on a good brake latheEmpty V wrote:
EDIT: If a brake rotor was truly warped I doubt resurfacing it would help because if you're clamping it from both sides you'll hit a gap. Also, it would no longer be symmetrical and probably act a lot like a wheel that wasn't properly balanced.
