Thanks for the info. Yeah I guess I could go with a bigger single turbo and it would be easier to plumb and probablymore efficient (less rotating mass) but the Z looks odd with just a single exhaust. I guess there are a few ways to solve that with a single turbo:qsiguy wrote:You don't need to reference the vacuum, just the boost pressure at the wastegate. I just have a tap from the compressor tube right at the compressor outlet in the back that goes to my boost controller then to the wastegate.
Twins would be a little more tricky but not too bad depending on how they were mounted. I saw a twin setup on an Acura that looked quite complex but I don't think they would all be that way. You only need one compressor pipe returning from the turbos. If you have an H or X pipe in the exhaust before the turbos, which most do, you would only need one wastegate If you don't have an X pipe I would make a crossover tube connecting the dual exhaust and put the wastegate on that tube. Also, since you should have the compressor tubes joined as soon as possible you only need to get a boost reference from that tube. The boost controller would be the same as any other turbo system. You could do dual wastegates and controllers but it could be tricky to match the boost settings.
Thanks for the pic. Yeah I definitely was thinking blow through, and I was gonna place my MAFS in pretty much the same place, but I was wondering how the emissions, driving is with the BOV so close to the meter. Do you get a lot of backfire, or excessive richness especially if you rev and let off? I would think when the BOV opens so close to the MAFS it would read some air twice when the BOV opens. You probably luck out since you are most likely running the stock automatic and don't get off the gas between shifts on a hard run. With a manual I would think it would want to stall on every up shift. Not to mention the turbulence from the tee in the pipe being there.qsiguy wrote:I've seen a few single rear turbos that used the wastegate for the 2nd exhaust outlet. I'm doing that but my tips are next to each other. The driver side tip is just the turbo outlet the inside tip is just for the wastegate. Mainly cosmetic to keep an OEM look, just larger diameter tips.
If you do a blow through MAF like I did you would only need one, if you want to do a draw through MAF you would need to run wires all the way to the turbos and have one on each compressor inlet. I wouldn't attempt this unless you just can't get it to work with a blow through setup. The tuning for a rear mounted dual draw through MAF would be a nightmare. Also, you will most likely skew the voltage signal to and/or from the MAFs from such long wiring.
Also with a draw through MAF setup you would probably need to purge the BOV back into the intake just before the MAFs, major pain if it's even possible with duals. With my blow through I was able to just put the BOV in front of the MAF so I can just purge unmetered air. Seems to be working great so far.
Here is my MAF/BOV setup
i dont see why you wouldnt be able to keep ur mufflers as long as you run ur turbo farther towards the front of the car.... i heard some one put it where their spare tire used to beclickdoc wrote:one more question -- would it be possbile in a rear mount turbo to keep your muffler -- i have the best looking mufflers on the planet & i hate to part with them ??
thanks
Technically from the way I see it, it is possible. Have the normal TT setup from the VG30DETT, then the rear mount turbos. Talk about overkill.devileyeam wrote:Haha! Thats funny!!! ^^^^
And I wanna see this quad turbo Z!
I want the dyno info, I plan on the swapping to the VH45DE and the single rear turbo would be a great add to it.Anyone got compresion #'s on the VH45DE? I just want to know how it will handle the turbo.qsiguy wrote:I'll be doing the dyno after I get it tuned as good as I can without the dyno. I have dual stage boost controller so I can get numbers at two boost settings.
i do beleive compression is 10:5:1........ but dont hold me to itOUKNO wrote:
a good reason to mount them back there is cuz at least that way you dont have to run a intercooler..... savs ya severl hundred dollarsevildky wrote:my only problem with the rear mount on the z32 is there si no reason to mount them back there, there are stock mounts to put a pair underhood, you save a lot on piping and it's just a lot easier, for other chassis it makes more sence
Can't wait to see the aftermath of this thing hopefully a little more dialed in than before are you having the pistons changed?please post any and all changes to the long block so us other NA guys just don't grab a turbo slap it in there and boom; another NA parkedyea that "10.5:1" compresion is a little high for boost especially above 6 psijaym5k wrote:Hey guys, I bought the rear mount turbo Z from the previous owner that started this thread. He blew his motor so then I bought it and have been putting everything back together. The guy should be done with-in a month and I will be putting up some pictures/ vids.
after talking to the guy that did the original rear mount turbo its a good idea to cut out the area for ur spare tire.... the area is tucked up under there pretty good so id think ull have any probelmsvalkyie wrote:Just wondering do you have any problems with your car on a rainy day? I thinking of doing the same with my car also. Just concerned about water getting into the filter.
its called the surface area of 8-10ft of tubingZXdriver wrote:I noticed no intercooler...? How does that work?
