the thing is, you have drastically different loads between, say, 7psi at idle and 7psi when the engine is turning 5000 in third.
turbos work because the load placed on the compressor wheel is roughly matched by the force applied to the turbine wheel. when you open it up, more exhaust gas flows.
you're going to have to do some rpm sensitive stuff with regard to this. and if you do the math, you'll see that the power gained by compressing air electrically will never be greater than the amount of power used by the device. thus, creating a LOSSY device...but this has an advantage.
This allows you to 'charge up' a spare car battery when you're not getting on it, and use that power when you punch it.
In application, i'd treat this thing as closer to NO2 than a real turbo. could be fun, tho!
