C-KWIK, I forgot about it having 2 solenoids, I remember now. They are also going to try to do away with the starter. In the theory, the computer will know which cylinder is on compression stroke and it will add fuel and ignite it to start the engine. Pretty cool stuff, we talked about it quite a bit in my Automotive Technology classes years ago. Masterman, I know exactly what you mean.....use a compressor that builds more boost at a lower RPM. I will eventually try that, right now I am using the stock compressor from my Grand National turbo. I have a motor that turns 30,000+ RPM, it pushes alot of air even at that RPM with a 1:1 ratio on the turbo. I'm going to try a 1:2 ratio and see if it can handle it. If so, we'll see what about 60,000 RPM can do. I've got the turbo unit ready, I just have to replace a diode on my PWM b/c I blew it on the last run I made
Hope to run it again in the next couple weeks. Gotta get some other odds and ends together.
