cory2081 »
https://forums.nicoclub.com/cory2081-u9472.html
Sun Dec 28, 2003 4:30 pm
Ok, after reading all these posts......I've already found a company that makes a motor that will work, waiting to get some info from them. I have tested static boost pressure on my brother's 5.0 Mustang with the 7 turn modified R/C motor running 12 volts.....I got 2 PSI and when removing it, I realized I hadn't plugged the fitting that was used for the wastegate. So, it had a leak.......and still got 2 PSI with the engine not running. That's a far cry from where I need to be, but, at least it's something. If the motor and gearing are all paired up right, it shouldn't pull more than about 30 AMPs continuous. Just have to get the right combo. As for boost control.....I have that covered with a voltage comparator circuit and a GM MAP sensor....oh, and a WOT switch. We want constant boost, yes, and full boost at like 1,500 RPM. If I can just get my hands on the right motor!! These companies sure take thier time answering e-mails.
