telcoman,I googled 91 octane vs. 87 octane mpg and got a lot of information, much of it supporting the claim that you would get better mileage from the 87 octane as it contains more energy. This goes against my gut feelings and the way I understand it, but there is quite a bit of authority supporting this premise. Maybe it is worth a little test on my part.telcoman wrote:
adren77
Your post and explanation is interesting because this is precisely the results that I have experienced with my G using regular 87 octane. Many G owners have posted getting very poor mileage using premium fuel and driving their vehicles hard.That has not been my experience. Day to day I get between 22 and 24 MPG with up to over 28 MPG on long trips. My 50 mile one way commute is mostly on cruise control between 70 - 75 MPH. There is no need for me to push my vehicle as traffic is light in the early morning & I usually shift between 2k & 3k rpm. Most of the $ssholes that clog our roads are not up yet. So I guess the point is that we can have our cake and eat it too, it just depends on how you want to drive your G
Telcoman
You need an X. No spinning tires.SVTCOBRA wrote:My cars love the cooler weather!!! Feels faster.But, my tires do not. They just want to spin.
Humidity may be clogging up your paper air filter.
zozo
Uhh? While the right amount of controlled turbulence in the combustion chamber is a good thing, the bellows in an intake are way too far from the combustion chambers to actually be effective in adding any turbulence in them. Simple swirl control valves would be much more effective and provide more controllable results at different RPM's than some bellows that might prove to be only a minor restriction that exists a good foot in front of the throttle body, the plenum and the runners. It would be likely that any turbulence the bellows might induce would have been dissipated by the time it goes through each part of the intake.adren77 wrote:C-Kwik...
The belows in the intake tubes are not there to reduce the vibrations/noise.
The reason for the belows is to induce turbulence. Turbulence plays a key role in the combustion dynamics inside an engine. More turbulence inside the engine, the better! Engineers try to induce turbulence inside the engine at every possible opportunity, and intake runners is one way.
The reason why turbulence inside the engine is important has to do with the combustion characteristics inside the chamber. Turbulent air will cause the flame front to propagate faster!!! We want the flame front to propagate as fast as possible. Faster flame front = faster combustion inside the chamber => less chance of knocking to happen => means we can get higher compression ratio => higher power + efficiency. Also faster combustion means the engine comes closer to having "constant volume combustion" (just as in the Otto cycle)... which will yield higher thermal efficiency.
Turbulence in the intake will cause more drag which is a negative side effect, however in this case, it is greatly outweighed by the positive gain explained above.
Jacko3Jacko3 wrote:Telcoman:
Nice conclusion---how then do we drive the G-35? Remember, i had asked that question on another topic?
From my experience so far, my car is getting exceptional gas mileage for the power output. My car is burning less gas now, then before I installed all the mods. Of course I use Mobi 5w-30 synthetic. And the mods I have on are Mrev2, JWT Pop Charger, 5/16" spacer, and Stillen Exhaust. I also use 93 Octane.
My car only drinks a modest amount of gas when i push the car. The car is now so fuel efficient especially in the 4th and 6th gears, usually between 3K and 4K RPM. However, i get the best mileage in the 6th gear at or below 3K RPM.
In fact, I don't look to often at the gas gauge anymore because the car is now using gas in a manner I would find acceptable for a V-6. I am now amazed at how fuel efficient a G-35 can be when al the mods are installed and when all the fluids running through the car are made of synthetic. This is why I am going to change my differential and transmission oil to synthetic, to further increase its fuel efficiency.
Until anyone has the money to buy a supercharger, which I am looking forward to buying someday, my advice is to mod out your G-35 and change your oil, transmission, and differential to synthetic fluids. The Stillen TD Cat-back exhaust alone is lighter than the OEM exhaust, and thus saves you some gas. I am also looking at changing the drive pulleys to non-underdrive unorthodox pulleys, if I don't get the money I need to buy a vortech supercharger. Again, the lightness of the non-underdrive pulley would shave some weight from the front part of the car.
I am also amazed at how inefficiently the G-35 was built given all I am experiencing with the changes I am doing to the car. It would also seem reasonable to buy those lighter after-market rims as well. I think shaving off any excess weight from the G-35 does improve performance, handling, and fuel economy.
I cannot figure out for the love of Jehova why Infiniti did not do these simple things to give the customer what they need. Of course I understand the noise issue with the exhaust. Was infiniti trying to skimp on costs or are the materials they used on the car really better than the after-market parts?
I truly beleive Infiniti intended for the G-35 to be modified by the customer for better handling, performance and efficiency. Time and time again, as i visit the philosophy behind the car's design, I see nothing but modifications. So, why Infiniti?
If the data that the guys who make spacers and plenums publish are accurate, their speculations are that the tapered plenum shape restricts the flow of air to the front cylinders as the plenum is narrower there. Spacers and aftermarketupper plenums are supposedly the solution for this...!979TransAm wrote:What makes the plenum biased to the rear cylinders?? Is it leaning back?? could a beveled spacer help to fix that?? Could be a simple fix.
I don't have exact numbers prior to mods installed. Anyway, engine is still new (5,000 miles) while rest of car is about 17K miles. However, prior to mod I was always going to the gas station to fill up all the time---my wallet was leaking cash like a gambler in a casino.
What I did was to ensure that my gas never went below a quarter tank. Then, I monitored how regularly I was going to the gas station to fill up. Well, at the time before mods I was using blend from Castrol, which did help with reduced noise and smoother acceleration. Fast forward a week after installation, and now I am smiling very happily--not worried anymore about gas.
The car is seeping gas like a 4 cylinder--not bad for a G-35--remember, I have another car that is a 4-banger manual transmission whishc I compare it to. In fact, the fuel measuring device on the GPS at 60 miles per hours read something beyond 26 miles per gallon. I had to reset it quickly because I thought it was an error. Give me this weekend to monitor it some more and I will post several numbers based on RPM and speed. This time I will use cruise control at varying set speeds to determine gas consumption with mods. I hope this helps. I am extremely pleased with the gas consumption at the moment, given that it is a V-6. I am also getting this improved gas mileage at higher RPMs with the mods than the slightly less RPM I received without the mods, given the same pedal input.
Only time it drinks gas is when I stomp on the gas pedal for hard driving---it doesn't matter the gear or RPM. The gas consumption is real and immediate. You will see the gas gauge needle move. So, I feel I am in total control of my gas usage now than at anytime before. However, I am finding that the 5th gear of the 6MT coupe is very inefficient. When I get to the 5th gear, I burn gas a lot more than in any other gear. So, now with the mods, I try to quickly move from 4th gear to the 5th gear and then the 6th gear. I enjoy the 4th and 6th gears the most, this is with the Stillen exhaust. With the OEM exhaust, without the mods, I enjoyed the 5th gear the most, eventhough it burned a lot of gas. But the 3rd gear burns as much gas but at much higher RPMS of about 5 - 5.5 K RPM. below this, the 3rd gear is okay and good. This is my experience so far with the car.
My mechanic also increased my timing by 2 degrees and the RPM at idling increased by a small and insignificant amount of 50 RPM. What this is doing is that it stops the RPM needle from dropping back to zero very quickly when I am shifting. Does anyone know what this slight increase in timing and RPM does for a car with high compression? My mechanic says it helps with immediate acceleration and power.
Let me note that the first three days of using the synthetic oil, I saw no difference in improved gas mileage as my car was shifting from a synthetic blend to a full synthetic oil. After about 3 days of hrad driving, I began to notice the difference in gas mileage. As at today, the gas station is not my friend anymore as it used to be. Any thoughts?
My bad, When you said "bellow" i thought you were talking about Intake runners.C-Kwik wrote:
The turbulence you speak of is really desirable once the fuel is mixed with the air. So at or just before the ports would be the ideal place for this turbulence to be added. Some motors offset the openeing events of each intake valve to induce some level of swirl. But any turbulence prior to this point would really just be a restriction to flow.
What you said here really doesn't make sense. More controllable results? Right amount of turbulence? We don't want to control turbulence in the engine, we want to get as much of it as possible, always. More turbulence = higher fuel conversion efficiency. The reason many cars suffer at low RPMs is because of low level of turbulence at low RPM.C-Kwik wrote:
Perhaps. Lets just assume I have no idea what I am talking about. And that's perfectly possible. But feel free to argue with this guy then:adren77 wrote:You really shouldn't try to argue points you don't understand.
I am guessing this is suppose to prove to me that turbulence dies inside the intake as you mentioned previously. Let me explain why this quote does not support your argument. He says that "[turbulence] rapidly decays away through viscosity once the bulk air speed reduces." This statement is true, however it does not pertain to the intake system. The "speed" of air does NOT reduce inside the intake. Assuming that the engine is running at a constant speed, then air is entering the intake system at the same rate it is exiting. This is the simple continuity equation most people see the first day of fluid dynamics class. Anyways, this means that the inlet mass flow rate = outlet mass flow rate. Assuming that the runner has the same diameter at both ends, then the speed of air entering it will = speed at exit (which right at the intake valve). Since the speed is constant throughout the runner, the turbulence does not "rapidly decay" but instead it increases! If you do a simple calculation, you will see that inside the tube Re >>2300 which is when it transitions from laminar flow to turbulent. This means that the air entering the the chamber is already turbulent. It does not have to be swirling, but it is still turbulent. The two terms are not synonymous.C-Kwik wrote:
http://www.fuelsaving.info/turbulence.htm
Feel free to read the whole article, but I'll quote some excerpts of particular interest to this discussion.
"Unfortunately turbulence is a very short-lived phenomenon; turbulence is generated whenever air flows quickly past a stationary surface, but rapidly decays away through viscosity once the bulk air speed reduces."
How does this pertain to what I was talking about? Yes generating more swirl does require more restrictive inlet ports... which is counter productive. This is why you would like to have turbulence even before it reaches the chamber, so you don't have to restrict the flow too much to cause swirl.C-Kwik wrote:
"Since generating more swirl requires more restrictive inlet ports, values around 0.5 to 1.0 are usually found in production engines."
If by "bolt-on" device he is talking about the intake runners... well then he is plain wrong. Intake runners can (and do) cause turbulence. If you ever looked inside the intake runners you will find the surface is not flat, but has bumpy/dent pattern... This is done to increase turbulence! If you look at your headers at the exhaust... the surface will be smooth and have no such pattern. This is done to reduce turbulence and this less drag (Less back pressure).C-Kwik wrote:
"But let's ignore all that for a moment and imagine that adding more turbulence does help fuel economy. Can a "bolt-on" device really increase the turbulence in the cylinder? The simple answer is no - the flow in the intake system is already highly turbulent at part load, with air speed past the throttle in the region of 200-300 metres/second. A device upstream of the throttle may make the air swirl there, but the swirl pattern will be destroyed as the flow squeezes past the throttle blade."
Maybe so. Just something I was told by a mechanic friend when I was a teenager and I've always kept 1/4 tank because of it. Will have to ask another mechanic I know about it. I just thought somebody else would have heard of this......Sentientbydesign wrote:SVTCobra,
I don't see how you could be sucking up crap from the bottom after your tank got low. The fuel pump should be pulling from the bottom of the tank at all times. Is it possible that the junk you're referring to is floating on the surface of the gas and when it gets too low you'd suck it up then?
Are you still assuming the bellow is the intake runner? Last I checked we were discussing the effects of a turbulator ahead of the throttle and it's affects on the amount of turbulence in the combustion chamber. And between the bellows and the combustion chambers, there are many changes in volume (or cross sectional area) and direction. So speed is not constant.adren77 wrote:I am guessing this is suppose to prove to me that turbulence dies inside the intake as you mentioned previously. Let me explain why this quote does not support your argument. He says that "[turbulence] rapidly decays away through viscosity once the bulk air speed reduces." This statement is true, however it does not pertain to the intake system. The "speed" of air does NOT reduce inside the intake. Assuming that the engine is running at a constant speed, then air is entering the intake system at the same rate it is exiting. This is the simple continuity equation most people see the first day of fluid dynamics class. Anyways, this means that the inlet mass flow rate = outlet mass flow rate. Assuming that the runner has the same diameter at both ends, then the speed of air entering it will = speed at exit (which right at the intake valve). Since the speed is constant throughout the runner, the turbulence does not "rapidly decay" but instead it increases! If you do a simple calculation, you will see that inside the tube Re >>2300 which is when it transitions from laminar flow to turbulent. This means that the air entering the the chamber is already turbulent. It does not have to be swirling, but it is still turbulent. The two terms are not synonymous.
The rough surface energizes the boundary layer of air. Essentially causing air that would otherwise not be moving to be moving. Or to put it more simply, it reduces the boundary layer that isn't moving.adren77 wrote:If by "bolt-on" device he is talking about the intake runners... well then he is plain wrong. Intake runners can (and do) cause turbulence. If you ever looked inside the intake runners you will find the surface is not flat, but has bumpy/dent pattern... This is done to increase turbulence! If you look at your headers at the exhaust... the surface will be smooth and have no such pattern. This is done to reduce turbulence and this less drag (Less back pressure).
Please explain what you mean more clearly.adren77 wrote:Then he talks about how flow is turbulent at part load. Yes this statement is true. Then he says how the throttle will "destroy" the swirl pattern. Yes this may be so, but once again this does not destroy the turbulence. In fact, the throttle will only induce more turbulence by tripping the boundary layer.
The video also shows that there is much higher velocity gasses at the throttle as the air goes around the restriction in it's path of flow. The turbulence that ensues well past this point occurs as the velocity decreases. The higher velocity areas are going to direct and convert any turbulance or at least a significant portion of it into laminar flow.adren77 wrote:Look at video of the flow through the tube. You can't really tell if the swirl is destroyed but you can tell that the flow gets more turbulent down the stream.
Absolutely, turbulence is not as highly understood as most other obsevable physics. But, I find it a bit hard to ignore someone with this type of background:adren77 wrote:Turbulence is one of the most complicated and least understood topics in all of engineering. Excuse me if I trust a source a little bit more reliable than "Tony's Website"
I was taught that with the FI Fords that the electric fuel pump was in the fuel tank. And that the pump was lubricated by the fuel it pumped. If you ran out/low on fuel you ran the risk of burning out the pump. I never liked the idea of having an electric pump in the fuel tank. That made for the best anti theft device, splicing a on/off switch in to the power feed to the fuel pump and hiding the on/off switch. Engine would start, run about 1 1/2 seconds and die. Flip the switch back to on, and she would start right back up.SVTCOBRA wrote:
