No kidding lol, EGT's no idea, don't have a gauge. Logan (my tuner) said my manifold was not unusual for a big turbo car. But there is a "bullet" something like that, summit muffler under like my seat, then the ebay fart can out back.240z4u wrote:Darius, I was not speculating the fuel to be the cause of power loss so much as just a problem to help troubleshoot.
Where is the muffler mounted? Up under the car? I would think it would sound different if the exhaust collapsed. I would imagine it would have to be pretty far upstream to burn out the guts.
Your manifold was glowing red? What did your EGTs look like, not sure if you mentioned that.
Evan
Man, would that be something if you melted a muffler LOL.
I'll get a hold of my buddy tomorrow whose camera I borrowed, he has all the footage. I'll tell him to send it over asap!matafied wrote:sweet great to hear it was nothing major. but you still owe us a small vid clip even if its just of idle and a small rev. im easy to please lol
Ditto. Glad to hear it was something free too!240z4u wrote:Great news man!
I would rather hear your retarded then have major problems with the motor LOL.
Evan
your not kidding! I thought the same, they are/were pressing themselves off slowly but surely... I wonder if the compressor surge is doing it... It will surge if I short shift like 3.5-4k and below after a bit of boost has been made. After that its all BOV. Tail 50mm if your wondering.Darius wrote:
So you are blowing couplers off of bead-rolled pipes? I thought bead-rolling was good enough to prevent that from happening.
Trust me lol, I'm very resistant to currently getting on the throttle. It suits me just fine to drive normal, even at that rate, its retarded loud under a bit of load. The noise alone makes me so happy lol.240z4u wrote:There is no reason to not drive it to your tuner, just don't be a lead foot.
Evan
hmm, I will have to check that, from reading it seems I might not have enough VAC, I'm only at 8-10" at idle.... with a bit of a rev it goes up, I'll monitor it closely on my way to school.Carl H wrote:check that the checkvalve for the brake booster isnt leaking...could be pressurizing under boost.
Yes, S-13's do. I just replaced my check valve.Shocker wrote:EDIT: do s-13's even have this valve stock since they are n/a?
I might need this... http://www.courtesyparts.com/M...BVHCV
I used the stock r33 vac line for my old setup.... I remember a piece of plastic in between the line that when to my booster....
Sounds like a good plan to me! better get out there I'm always game for a few pulls.gawdzilla wrote:good to hear about the car. maybe i'll go to carlisle to check it out and we can do a few runs
