glad you didn't go your b/f's route and sticking with right wheel drive.skylinegrl13 wrote:LOL!! that's my bf's project car, and yes it is REDICULOUSLY clean. can't wait to see that thing at the track, it needs to get a little dirty.
The 26 oil pan isn't that great from the factory. If you take that car on a road course there is a good chance that you will kill the motor due to a lack of oil. Talk to a few of the GTR guys on Freshalloy and they will tell you all about it.skylinegrl13 wrote:yes about that sway bar...it's sort of up in the air right now. i've read a few stories about just bolting up the stock bar backwards, supposedly it will clear like this but i haven't tried and it seems like cheating. Since i'm not above cheating i will hunt around for my old bar and see if it works like that.
Another way would be to get Whiteline to quit with the stalling and make a bar for this application. i contacted them last year about it and they were basically telling me they had thought about it but didn't have a car for design reference.
I will not "notch" my 26 pan as some others have done, i believe this would disrupt the flow of fluid and change a design that was maticulously engineered for a purpose. this is also why i would not use the 25 pan, simply because there is a reason that pan did not come on that engine from factory.
I like your idea of using an increased capacity 25 pan, it would definitely save some weight, but for me it was simpler and made more sense to change the bar and not the pan. And by change i mean, go without one until i figure out what to do!
*opens can of worms*skylinegrl13 wrote:yes about that sway bar...it's sort of up in the air right now. i've read a few stories about just bolting up the stock bar backwards, supposedly it will clear like this but i haven't tried and it seems like cheating. Since i'm not above cheating i will hunt around for my old bar and see if it works like that.
The 25 pan needs about 15-20 mins of modding for it to fit on the 26 with the oil pickup installed. The 26 has 2 sets of oilpan bolt holes. The inner holes line up for the 25 pan (cept a few that have to be enlarged) while the outer holes work with the 26 panArrow wrote:Hey guys, I've been doing a lot of research on the RB26 swap and since you mentioned about the whole sway bar situation, I have sort of a question for you...
I know why Nissan made the 26 pan for a specific purpose - but wasn't that purpose the incorporation of the front diff? If they in fact wanted to make the 26 pan completely unique and did not want the possibility of the 25 pan to be used without the front diff. then wouldn't they have simply changed the bolt locations of the 26 block? Although I am not aware of the differences between the 26 block and the 25 block - and I could see that if there aren't any differences than it would be senseless to try and move the bolts or whatnot...
Please enlighten me and help me further my knowledge or point me in the right direction so that I can find the answers.
BTW, your build looks impressive and CONGRATS on making it this far!
Oil cooler setup is NOT that expensive... I just did it. Break down the prices.skylinegrl13 wrote:LOL!Oil Cooler = $$ skylinegrl does not have. i'm pretty sure i can find or rig up a sway bar for less than $1400. plus, i don't think i need an oil cooler when i'm shooting for ~450, but i might go that route when i do the big single setup later on. this is a pretty stock setup other than ecu, intercooler, clutch, exhaust...seriously, that stupid thing is the least of my worries right now, if i can't get it to fit by the time this thing runs then i'm going without.
