why do you prefer C&R? are they significantly better than griffin?Coolwhip wrote:it doesn't matter how thick your radiator is. Its a heat exchanger and the quality of job they perform is the frequency that they pull heat out of the coolant.
Regardless of price, Griffin > Godspeed
But as I noted before C&R is the way to go.
Pictures? And where did you buy it?rb25drag wrote:Well I solved my cooling problems with a Generic Aluminum r33 radiator for 230$ shipped. My tempts doesn't exceed 170 now.
The taurus fan fit as a puller? I didn't think it'd be enough room for it...hmm...Though, the radiator I plan on using is the Mishimoto (1.75in)ANVIL wrote:i ran my stock sohc ka rad with a ford taurus elec fan for over a year, never had overheating problems. i dont think the radiator is ur problem. like others said, maybe its ur water pump or some other thing in your cooling system.
was kinda wondering about that myself...gawdzilla wrote:crush bent crossover hot pipe ftl
no. WAY to big. barely fits as a pusher too. had to do LOTS of trimming. i actually took it out and replaced it with a mishimoto, but it didnt fit as a puller either. well it might have. but i didnt like the clearance... just too little for me.Neejay wrote:The taurus fan fit as a puller? I didn't think it'd be enough room for it...hmm...Though, the radiator I plan on using is the Mishimoto (1.75in)
If it DOES fit, that'd be awesome, because I already have one. lol
How much did that PBM radiator cost, shipped?
I love your temp meter!Coolwhip wrote:170* Thrilled 180* Happy 190* Content 200* Eek +* Sad
top of the line.SStrunks wrote:anyone knows if fluidyne is any good?
The Block was dipped into the Hot tank when built. All the water jackets were completly cleaned of corrosion.Coolwhip wrote:just a quick thought, have you looked inside the block when doing the water pump? what was the condition of the cavities?
and forgot if you did any type of ducting.
I ran all day at 170* @ 90* atmopheric temps.
Twin FAL, KOYO, oem water pump, thermo, and oil cooler. Give that with a huge turbo causing great under hood temps (which btw is wrapped along with manifold and dp).
What gauge are you using to read these numbers?
And if anything, leak down test your cylinders and make sure their not blowing hot compression gas into the cooling system.
And for those of us who don't use antiquated measurement systems based on arbitrary data. :Coolwhip wrote:170* Thrilled 180* Happy 190* Content 200* Eek +* Sad
