IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Mon Jan 26, 2004 4:07 am
if you know the code, i would be able to say.
it would come down to the case, and the shaft spacing. the rb25, rb26[not r34], and z32 share the same spacing and gear ratios.
the z32 and the rb26 trannys differ by one letter in the model code. i read somewhere that a person building a cefero [sp?] wanted the shifter to be farther forward so they replaced the front case on a z32 transmission with the rb25 transmission.
supposedly the bolt pattern of the front case on the z23, rb25 and rb26 [not the r34 getrag] are identical. [I MEAN FRONT CASE TO CENTER BEARING PLATE, NOT BELLHOUSINGS] the bearing plate is also supposedly the same between the familys.
the gearsets, although the gears and ratios are the same, the shafts are different at the rear portions [z32 is short, rb25 normal, rb26 long to support transfer case]
i took a trip to the junkyard to look at a z32 trans, and compared it with pictures of the rb25/26 front cases. i would say that it is possible, and others have said it has been done.
im going to get an r34 clip, and im also getiing a r33 rb25det trans, because the case is different on the getrag unit. i am most likely going to need the shifter to be forward inorder for it to line up on my console so i will be able to say with absolute certainty when i do it.
