From what I can find they offered 2 different automatic's for the inline 6 cylinder Skyline
- M-ATx: Dualmatic M-ATx full-range electronically controlled 4-speed automatic transmission with a manual shift mode
- E-ATx: full-range electronically controlled 4-speed automatic transmission with a wide lockup range
Sounds like you're looking for the first of these, and it was offered on the 25-GT Turbo & 25-GT V. You may want to get the steering wheel, "Models fitted with the M-ATx automatic transmission also have shift buttons mounted on the steering wheel." (according to a 2000 Nissan-Global press release)
More from same press release..."The Skyline also comes with the "Dualmatic M-ATx" transmission, a new automatic gearbox featuring a manual shift mode. The Dualmatic M-ATx combines the driving ease of an automatic transmission with the direct shiftability of a manual gearbox. With this transmission, the engine brake clutch is engaged to quicken acceleration or deceleration response to throttle inputs in all gear positions, which vastly improves the direct G feeling in relation to the operation of the throttle. Shifting is possible either by the shift lever or by the shift buttons mounted on the steering wheel, thus providing a "dualmatic" feature for enhanced driving performance befitting the Skyline."
NICE find while researching the Dualmatic M-ATx
According to this 2001 press release "Adopted as the gearbox on the 3.0-liter models to provide smooth, crisp shifting together with improved fuel economy is the 5M-ATx full-range electronically controlled 5-speed automatic transmission with a manual shift mode and incorporating a new shift pattern." Looks like it may only be offered on the 3.0 liter V6??
