Cjmartz2k wrote:Oh, and BTW, you meant to say "I wasn't talking sh*t to u." Also, we start sentences with capital letters in the english language as well as using an upper case "I" when referring to ones self. "tookn"? I'm guessing maybe you meant "Taking?" And I didn't say no motor is worth it, I said an RB20 isn't worth it. They aren't worth messing with when they come stock in the R32 GTSt's they come in (unless you are talking about drifting) and they aren't worth putting in to another car, when an RB25 is not much more to put in. What do you think can in the car you see in my sig? I've done both and can speak from experience. What experience are you using to compare the cost vs. benefit ratio of RB20's vs. RB25's?
I got a question for you. Why is the rb20det worthless but the sr20det is soooooo damn good? both 2 liters, both stock turbo, both make just over 200hp from the factory. I dont know looks like it comes down to how they are made to me. Lets do a small side by side:
rb sr
I6 1998 cc, bore: 78.0 mm, stroke: 69.7 mm I 4 1998 86.0 x 86.0mm
This is the main diff between the two 2liters. What are you talking about you ask. The rb has a smaller bore and stroke, but it has two more pistons. The shorter stoke WILL be able to make more lbs on equealy built motors. On top of that, lets say both motors make 300hp. The rb is not working as hard as the sr to make the power. You need 75 hp perpiston to get 300 out of the sr. With the rb, you only need 50 hp. Still dont get it. A 300 hp rb20 will not work has hard or be put throu as much strain as a 300hp sr, thus meaning the rb will last longer(not to mention the rb is built stronger anyway). Granted 300hp on both is not that big a deal, but what if you change that 300hp to say 600hp.
I dont get it, who said anything about the 25? We know that the 25 is better. ITS A BIGGER MOTOR DUMBASS. I wanted one, but did not have the money. When I was shopping around(two months ago mind you) the rb25 was going to run me about 1500 MORE THEN THE RB20, and that was using an ebay motor set. I did not have that much extra just sitting around.
