Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Mon Apr 12, 2004 4:22 pm
if the ecu says that its all good then perhaps its the injectors.i would pull the injectors and have them cleaned and see if thats the problem.what about fuel filter?if its never been changed then it will most definately cause hesitaion as they do get clogged.change it out to a 300zx fuel filter, works fine.try the filter bit out first then the injectors, else i have no idea.mebey a damaged MAF.*edit*come to think of it it probably is a clogged fuel filter.i had a friend who had a honda prelude that wouldnt rev past a certian point no go above a certian speed.replaceed the fuel filter and all was good.
