Postby
wcbjr »
https://forums.nicoclub.com/wcbjr-u6827.htmlThu Aug 28, 2003 8:51 pm
Can anyone comment on the size of the water passage holes in the head gasket? Are they supposed to outline the passages on the block and head, or be smaller?
Postby
JCAP_Tuning »
https://forums.nicoclub.com/jcap-tuning-u9361.htmlThu Aug 28, 2003 8:51 pm
NGK PLAT(hot)PFR5A-11 (4588)ngk iridiumBCPR5EIX-11 (3306)Denso iridium IQ20OBX iridium ???(have to look at that one again)use denso x refngk plat(cooler)PFR6A11 ngk iriduim BCPR6EIX-11 ngk cheap copper NGK BCPR6EY-11(cooler and 5EY is hotter)Autolite 3924/3923(cooler) forgot silverstone and hks
Vudodoc, these you listed are they basically the same as z32 TT or N/A?
Postby
wcbjr »
Got my head studs back from Paeco, they look totally different than the last ones. Huge nut/washer and different stud material. I emailed em to see what kind of metal they are. Going right now to see if it fits in the block.
Postby
fito »
https://forums.nicoclub.com/fito-u11706.htmlThu Aug 28, 2003 8:51 pm
Hi, just for your info, I just installed a NEO RB25 engine (98+) and here is a list of what is different from earlier R25:-Cams-CAS (cam angle sensor)-coils-clutch-cam shims
Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlThu Aug 28, 2003 8:51 pm
um..... transmission fluid i would guess.im putting redline mtf in my rb20.the only diffrence with the rb25 transmission is that its bigger and beefier.
Postby
Toad[^_^] »
https://forums.nicoclub.com/toad-u6768.htmlThu Aug 28, 2003 8:51 pm
vududoc wrote:300zx fuel filterka oil filterspark plugs i believe IQ20 and then Xreferencehell you know what goto my geocities and its right there for download. im gonna piece on more stuff too
sorry for any repeats:
Spark plug NGK PFR5A-11 on the RB20s PFR6A-11 on the RB25s and 26s. Oil filter Fram PH3682, PH3614 or PH8A if you can get it to the mounting location past the strut towers
Bosch 3400
Modified by Toad[^_^] at 1:07 AM 1/17/2005
Postby
Yellow4g63 »
https://forums.nicoclub.com/yellow4g63-u4416.htmlThu Aug 28, 2003 8:51 pm
Ok I emailed Courtesy Nissan about the idler pully and tensioner. They have the tensioner in stock but the Idler is something like a 6 week wait. I haven't got a price yet but shouldn't be too damn bad I'm ordering as soon as I get the reply about the prices.
Postby
Carl H »
hey all.ive found an o2 sensor that works.its from a 1984 200sx with the ca18et engine.has the right wires and has the same cable length as the rb's.seems to work well for me right now.
Postby
salyardsk »
https://forums.nicoclub.com/salyardsk-u14375.htmlThu Aug 28, 2003 8:51 pm
The RB25DET shifter has larger diameters on the end that has the nylon sleeve which goes into the transmission, and the pivot ball at the top of the transmission.
