DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Sun Jul 15, 2007 6:34 pm
RB20, you wont be dissapointed with the power, and it will probably be least likely to kill you. Do the motor that fits your budget, which will likely be the RB20.. Replace all your gaskets. I understand the headgasket might be kind of overkill, but definately the intake plenum/manifold gasket (I lost a motor to this gasket), exhaust manifold gasket, Throttle body gasket... Also, water pump and timing belt/tensioners are important, as well as a thermostat and as many rubber hoses as you can.
All this might seem like a lot of work with the motor out of the car, just itching to go in the bay.. but trust me, when any of these things fail, replacing them in the car is 100x worse.. Or even worse than that you could loose a motor.
Do it right the first time, do it smart, and be patient.
Rb20's bolt up using the skyline crossmember, and then use a stock 5 speed driveshaft, and I think the transmission will mount up with the s13 automatic transmission mount, but I could be wrong.
All that aside, if you're still learning how to drive, do brakes and suspension, and maybe a set of sticky tires in the front (since we all know you're going to drift off the rears), learn how to drive your car before you get dreams of big horsepower..
