 RB20DET vs RB25DET vs RB26DETT FAQFirst  1 2 3 4 >  Last
krayton
Tucson, Az
6-24-2003
Ok here it is. Im thinking we make a faq comparing all the engines. Now we know the rb26 is top, and the rb20 is bottom. Lets just shoot some info out on all the engines to help other people decide on engines. Also lets leave price out of comparing engine to engine cause that always turns into the deciding factor anyways. Everyone shoot there feelings or good info on a specific engine. I can edit it in to make it easier. try not to get in arguments. if you disagree just say so. no need to make a fuss about it. Mod is gonna be strict on this one to make it clean. damn right i am. if this turns into a flame fest ill lock it and we will never discuss this topic again -Kamin
*this is just trying to make things a little easier for other people
General
Pros
-its an RB! from a skyline!
-closest thing to a real skyline
-I-6 potential
-the awesome sound.
Cons
-Yes, it is more weight, around 150lbs more for a rb25 swap. the weight isnt important tho, its the weight shift. it really depends on engine/transmission and how you mount it (i.e. crossmember or aftermarket mounts), but realistically your looking at 2-3% overall weight shift. if you look at the numbers in a 3000lb car thats only a 60-90lb shift forward. just to put that in perspective, 12 gallons of gas weighs roughly 100lbs so there is more of a shift between a full and empty tank, than a RB swap. IT DOES NOT DESTROY THE WEIGHT BALANCE OF THE CAR
-Parts are still rare and expensive, but things are starting to come over
-mounts or crossmember swap required
RB20
Pros
-cheap
-skyline engine (?)
-WD-racing was saw near 400hp with his
-easy swap
-free revving up to 8k is possible on stock valve train
-excelent gas mileage off boost (it is a 2l after all)
-can make good power with minimal mods.
-sensors interchange with lots of usdm cars
Cons
-SR is easier with same potential (for your lower goal people). out of the box both will make near the same power, and upgrade easily to near the same numbers.
-cheap turbo (ceramic wheel)
-"weaker" tranny, nearly the same as KA/SR trans
-akward intake manifold
- its getting old 89-93 production years
-high mileage engines need proper mantinence ie timing belts and water pumps
- tiny injectors (270cc)
-intake manifold flange is diffrent from rb25 (greddy manfold does not bolt on)
-some rb20's can have the same problem as the early rb26 engines with the crank collar issue
RB25
Pros
-good potential (500+ on stock internals)
-VVT
-strong tranny (also include this when you price rb25s)
Cons
-expensive clips (when you get that strong tranny)
-becoming rare and expensive parts
-weak pistons ring lands
-not full glory as rb26
-another lame turbo, but better than the RB20's
-factory hp overrated (easily achieved with basic swap upgrades though)
-side feed injectors (hard to find)
-custom driveshaft required (unless you use RB20 tranny?)
RB26
Pros
-the GODZILLA of RBs
-most potential of all
-twin turbo stock
-upwards of 300+ out the door
-bullet proof
Cons
-r32 crank coller issue (kills motor)
-need for rb25 tranny
-hard to find r33 motors
-impossible to find r34 motors
-did we mention $$$$$?
RB30det hybrid
Using the higher displacement 3 L block from the RB30 engine mated to the RB25 or RB26 head can yield a very powerful engine. Here's a thread with details. http://forums.nicoclub.com/zerothread?id=188136
For Specs on engines and good info also check:
- http://www.meggala.com/nissanrb3css.htm
check your MAF (wiring, clean, etc.)
Team Race Bread - P&J forever!
Joe
Tucson, AZ
2-9-2003
 « Re: RB20DET vs RB25DET vs RB26DETT FAQ (Kamin)
thread has been updated and cleaned. please feel free to keep commenting on this
i like where its going.
-Joe
1997 240sx SE - LS1
2005 Nissan Titan SE - Tow Vehicle/Daily driver
TOPSECRT88
S14
USA USA
4-3-2005
Awesome sticky man. This should eliminate the 100,000 RB20 v RB25 v RB26 swap topics. We shoulda thought of this earlier.
Joe
Tucson, AZ
2-9-2003
 « Re: RB20DET vs RB25DET vs RB26DETT FAQ (BuddyClub240)
i agree
i also think we need a RB VS SR VS KA sticky
but i dunno if that would go over well in the RB forum needs to be in 240sx general haha
Nameless EJ6
What the **** do you think.
Seattle, WA
5-12-2003
I'll chime in soon.
Excellent sticky!
89' 240sx hatch
RB26DETT in the works.
http://www.myspace.com/twistingmearound
Kansei240sx
Online
91 240sxHatch RB25DET, 86 AE86 Hatch 5SPD, 2008 Honda Ruckus 49cc gas saver!
Tulsa Ok
11-1-2004
I think you guys should differentiate the series of RB motors with in the 20 and 25
Modified by Kansei240sx at 8:31 PM 10/26/2007
SI RB25DET -313rwhp on stock turbo
New HOLSET HX35 build approaching
-Racing House Shift- ( Tulsa, Oklahoma )
Quote, originally posted by S13 240SX »
one time, i ate a whole bag of marbles
Eikon
Super Moderator
Online
'92 240sx 'vert with RB20
Green Bay WI
4-24-2004
 « Re: (Kansei240sx)
I beleive this info is correct: (**Edit - info reviewed and corrected by Gawdzilla)
RB20det = Top feed high impedance injectors. Stock is 270cc. Each injector will pass on about 10 ohms. Each is wired in parallel so that the total return to the ECU is ~10 ohms.
RB25det = Side feed high impedance injectors. Stock is 370cc. Each injector will pass on about 10 ohms. Each is wired in parellel so that the total signal return to the ECU is ~ 10 ohms.
RB26dett = Top feed Low impedance injectors. Stock is 440cc. Each injector will pass on about ~ 2 ohms. Each injector is wired in parallel to the ECU but in Series with a resistor. That resistor passes on about 7-8 ohms. The two signals add up to ~ 10 ohms returned to make the ECU happy.
Modified by Eikon at 7:55 AM 9/21/2005
Wisconsin Nissan and Import Meet and Greet. 9-20-08 Fond du Lac, WI
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
gawdzilla
none
9-18-2004
 « Re: (Eikon)
Quote, originally posted by Eikon »
RB26dett = Top feed Low impedance injectors. Stock is 440cc. Each injector will pass on about 1.5 to 2 ohms. All injectors are wired in series so that they add up to return ~ 10 ohms to the ECU. (6 x 1.67ohms = 10 ohms)
that explanation/calculation should be corrected...
injectors are still wired in parallel, but a resistor is put in series on the +12v side of each injector. Each resistor (there are 6 in the box) is ~7 ohms, and the calculation is ~2 ohms per injector + ~7 ohms per resistor = ~9 ohms per injector pin for the ECU to ground, reducing the current going through your ECU so it doesn't fry.
Modified by gawdzilla at 12:18 AM 9/21/2005
Just your average dreamer looking for a 240
http://forums.racebread.com
TOPSECRT88
S14
USA USA
4-3-2005
 « Re: (gawdzilla)
Just a quick question......
exactly how much power can the stock internals hold on an RB20?
Thanks
masticatingcow
94 Mazda FD3S
CA
11-7-2003
Quote, originally posted by TOPSECRT88 »
http://forums.nicoclub.com/zerothread?id=135005
Maybe this will help.
dezi
1992 nissan 240sx
calgary ab
6-27-2005
how much are you looking at for a custome drive shaft for the rb 25
krayton
Tucson, Az
6-24-2003
 « Re: (dezi)
Quote, originally posted by dezi »
i paid 330 for mine. that was a complete driveshaft including new ends. if you use parts you have, it would be cheaper.
JDMEnthused
Nissan 240SX
Rock Hill SC
7-19-2005
hmm i think imma order me a RB20 from Jarco and stroke it out using RB26 internals( i need torque!)
Anyone Wanna Trade their Manual SW20 MR2 for my S13?
NICO REGIONAL MEET MARCH 18TH, 2006 - GREENVILLE,SC... PEOPLE ARE INVITED FROM ALL OVER BUT MOST WILL BE FROM SC/NC/GA
dsm007
1990 nissan 240sx
Vero Beach florida
5-8-2005
 « Re: (Eikon)
so I guess with
so I guess an RB20 is topfeed fuel rail,and it uses low impedance injectors,the injectors use a fat nose like a bosch?Or one that slims down and inserts inside on the head instead of like sitting on top of an o-ring,the DSM(eagle talon turbo's and eclipse's) 450's are LOW's and insert inside of the head,they would seem to be an easy one to find and could work.....anyone try them?
masticatingcow
94 Mazda FD3S
CA
11-7-2003
 « Re: (dsm007)
RB20 injectors are high impedance top feed. The 26 injectors are a better match, since you need to wire in resistors parallel to the ECU anyway... and at 440cc, they're nothing to scoff at.
Joe
Tucson, AZ
2-9-2003
 « Re: (Kansei240sx)
Quote, originally posted by Kansei240sx »
I have the SII motor and it doesnt not have the ceramic wheeled turbine, nor does it have VVT.
S2's have VVT, thats what the big hump on the front timing belt cover next to the CAS is.
Swedish Mike
Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Sweden
9-28-2005
How about the crank shafts, can you use RB26 crank in a 20 or 25?
Only asking about lenght and bearing size, not stroke.
This engines got pretty much the same block right? (Accept bore.)
Wanted: Visa or Greencard, e-mail me if you need a personal car slave.
Open for ideas, husband or wife.
eh?
1-24-2004
 « Re: (Swedish Mike)
Quote, originally posted by Swedish Mike »
Yes you can use rb26 cranks in both. No they're not the same block. RB26 supposedly had larger or stronger webbings.
Swedish Mike
Sweden
9-28-2005
 « Re: (eh?)
Quote, originally posted by eh? »
Thanks!
Ah, ok. But the RB20 and 25 is probably strong as hell, even the small CA18 block or the aluminum SR20 can handle a lot with forged internals.
The crank thing is good, I found forged ones to the 26 but not the others.
Do you know if I can use 26 cams in the 25 head? Diameter and lenght?
/Mike
Nismochick240
NICO Spokesmodel
95 240sx- BONE STOCK.. for now
Greenville SC
9-7-2005
ok i have a question. I am starting to think that ka-t is not the way i want to go. Its about the same amount of money for an rb25 but you just dont get that SKYLINE sound! hehe!
So anyways, on this custom driveshaft, where can you purchase one at? I was looking at the "where did you get yours" thread and saw 300plus picked a rb25 clip from jarcoinc.com and it came with a stock driveshaft. Can I use that one or would it have to modified in someway? thanks guys!
My Wish List- Sell me your PARTS!
91 240sx Hatchback- RIP
90 240sx Hatchback- SOLD
95 240sx coupe- (bought 7/25/08) MODS so far: S Tech Springs
Next: 5spd swap and Kouki front end....
Joe
Tucson, AZ
2-9-2003
 « Re: (Nismochick240)
Quote, originally posted by Nismochick240 »
it needs to be custom. you use the yoke (part that goes into the transmission) from the skyline/300zx and the rest needs to be shortened/made.
call a local driveshaft shop for estimates, they are in the phone book.
BTW that could have been easily found by searching if your seriously considering a RB swap the search function needs to be your best friend because its not anything like a KAT or SR.
Nismochick240
NICO Spokesmodel
Greenville SC
9-7-2005
yea i'm searching right now for stuff on the RB. hmmm...My dad owns a machine shop. I wonder if he could shorten it. I'll search a lil bit more before i ask any questions
Wulfgang
Champaign IL
10-28-2003
Hmmm... maybe we should also get a sticky (or just another thread) where people post FACTS about the weight change. I did not weigh my S14 before or after the swap, but here's my fact:
My floor jack now has MORE clearance (about 1/8") when I push it under the front lip. This is after swapping to RB20, including everything but cruise (kept stock A/C, battery location and size, SMIC, etc). In addition, I now have two PermaCool High Performance fans in front of the radiator, which probably weigh about 5 lbs more than the stock fan setup (they have steel frames and heavy motors). I also have the N1 Dual exhaust, which would seem to be heavier than stock, but I did not weigh it.
At any rate, the springs don't lie. There is no arguing that the RB20 is heavier than the KA24DE, but the center of gravity must have shifted backwards a bit to make the front lip come up. Perhaps that is the extra weight of the exhaust. No matter... the balance has shifted toward the rear, and that ain't bad.
[EDIT] In case I am not being clear, my basically stock RB20 swap shifted the balance favorably toward the rear wheels.
Joe
Tucson, AZ
2-9-2003
 « Re: (Wulfgang)
im all about getting the weight balance bull**** taken care of
only problem is only a very select few people have weighed their cars PROPERLEY before and after the swap. and only 1 to my knowledge has corner weighed the vehicle. i have access to corner scales at work but have never gotten around to doing my car. maybe i should..
Shocker
Youngstown Ohio
8-1-2004
 « Re: (Kamin)
I was considering this idea as well, i have a local Lafarge around here.. "mining company" they have trucking scales all good to within 10 lbs, i might bring my daily up there sometime, fully wet, and put her on the scale, then take the project once thats done.. see the difference.
RETIRED NRRB Since 3-17-08
RETURNED to the NRRB 8-9-08
Flicktitty
92 Z71 / S13 Coupe
Delavan Wi
9-21-2004
thanks!
I was here when you were still on honda-tech
PROJECT 300SX
andrewmp6
kentucky
9-25-2005
2 kinda dumb questions will the rb26 main bearings fit the rb25 and will a intercooler kit for a r33 fit a s13 or will i have to make it fit
mugengsr
SKYLINE GTS-T TYPE-M
Mount Pearl nfld
3-8-2005
 « Re: (andrewmp6)
main bearing in all three rb`s are the same
http://WWW.NFDRIVER.COM
89' NISSAN SKYLINE GTS-T (RB24)
97' NISSAN 240SX LE (RB26 SOON)
David_NISMO
RB26DETT powered S13
Kalamazoo MI
4-3-2006
 « Back on Topic
The RB25 crank is not FULLY counter balanced. The RB26 is.
My favorite part about the rb26 is that the entire motor will support over 425RWHP before any modifications need to be made.
This includes, injectors, mafs, turbos, and ofcourse all internals.
it also has internal throttle bodies which create better engine response
Stock bottom end has been taken to over 1000hp.
RB25DET is 9:1 Compression, better low end torque
RB26DETT is 8.5:1 Compression, bring on the boost baby!!
All RB motors are basically Factory Blueprinted. I love seeing the look on people's faces when I tell them that.
Joe
Tucson, AZ
2-9-2003
 « Re: Back on Topic (David_NISMO)
its individual throttle bodies, not internal.
sure the engine can see 425whp without much modification but the 10,000$ pricetag for a 26 swap you could fully build a 20 or 25 and see 600whp.
all engines are "blueprinted" thats the list of specifications found in any service manual that is used when the engine is assembled.
David_NISMO
Kalamazoo MI
4-3-2006
 « Re: Back on Topic (Kamin)
I'm totally borrowing this from Race Bread
Yes, different engines have different size bearings. Instead of a one-size-fits-all-hope-it-works system like some low budget engine manufacturers we won’t mention here (Chevrolet, Ford, etc.), Most Japanese manufactured engines run on exact clearances (blueprint). Because the machines work engine after engine after engine, tolerances vary. To make up for this, there are different bearings, pistons, etc. to choose from. For example: Standard main bearing thickness for grade 1 for the SR20 is 1.977-1.980mm and grade 6 is 1.995-1.998mm (There is only one size for undersize bearings). That’s a 0.021mm or 0.0008” difference between the thinnest and thickest shell for a total of 0.042mm or 0.0016” total difference per journal. This system works awesome in two respects; it ensures that every engine leaving the factory has spot-on clearances (Yes, this means that the RB26 is, for the most part, “blueprinted” in stock form), and it gives high performance engine builders a range of clearance options. The “old” way for “the other” engines is to mike bearing after bearing to try and find a thicker or thinner one to meet your needs.
all of this is from Matt... the skyline pimp... i take no credit i just was lucky enough to get the information
That's all I know.
Thanks for the correction on the ITB, I was a bit tired.
Joe
Tucson, AZ
2-9-2003
dude all engine manufacturers use a specific set of clearances for bearings and wall clearances and runout and thrust and everyother thing you measure in an engine when assembling. thats what blueprinting is.
David_NISMO
Kalamazoo MI
4-3-2006
o.k. so what's the big deal with people having their motor's blueprinted.
Does that mean that a lot of rebuilds, people used to just slap in some bearings and call it good? And those who get theirs "blueprinted" just means they took the extra time to get their tolerances as exact as they can?
Note to Moderator:
Thanks, and feel free to delete these last few posts as they are definately off topic
Joe
Tucson, AZ
2-9-2003
 « Re: (David_NISMO)
if anyone just slaps bearings in an engine they are building, they should not be building an engine. measuring for exact tolerances is a necessity when building an engine and every good engine builder on the planet knows this.
all blueprinting means is its built within the specs as the manufacturer reccomended in the service manual.
David_NISMO
Kalamazoo MI
4-3-2006
 « Re: (Kamin)
okay, thanks
Black on Gold
Jagermeister
White Zenki
Cohoes NY
10-12-2005
 « Re: RB20DET vs RB25DET vs RB26DETT FAQ (TOPSECRT88)
Word. Thats my dilema right now
NICO's Hockey Player
tyndago
3-28-2003
Quote, originally posted by David_NISMO »
The factory 26 crank is not fully counter balanced.
Around 400 whp you run out of MAF. Stock injector is a 444cc that runs out at about 440 hp at the motor safely. Stock turbos lose ceramic exhaust wheels.
I have done 654 rwhp on an internally stock 26, and I have ran 137 mph with an all stock internally 26.
The 26 has individual throttle bodies.
As far as stock and 1000hp....like a ticking time bomb. 500 rwhp it will last ok. 600 whp its iffy...
Sean Morris
http://gtrusa.blogspot.com/
http://tyndago.googlepages.com/
jimapaloooza
Atlanta GA
6-27-2006
 « Re: RB20DET vs RB25DET vs RB26DETT FAQ (krayton)
Well this is my first post on this site, hopefully I won't sound like a total idiot. But, I, like so many others have to come to the conclusion that front wheel drive cars just aren't near as much fun as rear wheel drive cars, so in following this train of thought I have decided to do an RB swap, the trouble I am having is, like all of the other poor "ignorant to the nissan world saps", is which engine is best suited for my needs/goals.
At first glance I, of course, wanted an RB26, seeing as the cost difference in the actual clip was only about 2-3k more than an RB25, but then I began researching what actually went into a swap and what the actual cost would be, and I think I have come to the conclusion that the RB26 is going to be a much more expensive swap compared to an RB25 swap, or perhaps I am just under estimating the cost of an RB25 swap?
So I guess my real question is, If I do an RB25 swap how much more am I going to need after I buy the engine, trans, ecu, wiring harness and how much will it all end up being? Also how much HP can I expect out of a 25, my goal is around 400WHP, would that achievable with an RB20?
Thanks in advance guys.
-Jim
Modified by jimapaloooza at 11:39 PM 6/27/2006
TougeRBSilvia
RB25det S13 Widebody
Del Mar CA
7-19-2006
Quote, originally posted by krayton »
under the the Rb25 cons you listed the above
ok i need someone to clarify this one for me... will an RB20 tranny mate with an s13 drive shaft??? or do you need to get r32 gts-t drive shaft or is it a trip to a drive shaft shop and a shaft in the wallet
gbaz77
240sx
columbia md
3-27-2006
 « Re: RB20DET vs RB25DET vs RB26DETT FAQ (TougeRBSilvia)
rb20 trans will work with s13 drive shaft. many people have done it, including myself.
you know you're driving a real car when you can let your shaft hang.
