RB = Ricky's Briefs
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Thanks zilla, I was going back and forth with myself on using them or buying a Tomei or Greddy Metal Gasket kit for that side.
Will make use of the paper ones now and take your word on the RTV as well.
StricNyne
i got oem metal, u suggest ne thing with that ?
sorry for the THRIZ-ED JIZ-ACK !!
Shocker
Car: 89 240sxHB rb26/30
what did you use to seal the rear drain? Just RTV or you make your own gasket? Also what size fitting is that on the drain pipe?
gawdzilla
Car: none
StricNyne wrote:i got oem metal, u suggest ne thing with that ?
for the metal i'd probably just keep the surfaces clean and put it on. maybe use some copper spray to give it some tackiness/thickness (that aerosol headgasket stuff). I think the main reason mine failed is because of many re-uses. The smaller gaskets tend to warp and stuff. With paper gaskets you're kinda forced to throw them away
the paper just seems a bit more forgiving to surface imperfections, but probably not as durable as the metal ones. the metals are more expensive and probably seal better if they are fresh and you install them right.
Coolwhip
Vendor
It fits perfectly into that upper Oil plug in the back of the head when you pop it out. The fitting has a large o-ring that snugs it in there tight. There are set screws that go into the back of the head which everything was RTV for added assurance.
The fitting is a whopping -12AN which runs down to that weld on -12AN bung on the sump. (just gotta buy the line )
Shocker
Coolwhip wrote:It fits perfectly into that upper Oil plug in the back of the head when you pop it out. The fitting has a large o-ring that snugs it in there tight. There are set screws that go into the back of the head which everything was RTV for added assurance.
So is there a little circular pretrusion of the drain plug that slides into where the welsh plug was? Or did they cut a circular groove into the square part of the drain plug and place an o-ring in there? Did you happen to take any pictures of it by chance?
Coolwhip
Vendor
Not my personal head but gives you the scoop...
Shocker
thats what I thought thank you very much for that picture!
Coolwhip
Vendor
Alittle update, which is behind date
And my 25 is up and going...
Shocker
nice nice, more info on this up and going 25?
Coolwhip
Vendor
for those who over look the aft motor
DanCouga
Car: 1997 Nissan 240sx
I recognize that engine, hoist and stand! THIEF!
bumblebtuna
Car: rb25/26 2fotay
Shocker wrote:nice nice, more info on this up and going 25?
x2
StricNyne
u scored a 30 block i am JELLY
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
its a RB25/(CAR) that he pretty must stole from a poor guy that is both of our friends..lol....not much of a mechanic , had it sitting at his house for months thinking it was badly hurt (which it wasnt and i tried to tell him that). the previous owner did not listen to me and couldnt fix the car himself and sold the damn car to (coolwhip)..congrats to coolwhip on getting a kickazz deal and having to do SOOOO little to get her going... wonder if Jay has heard the news,have you told him yet cause i know i havent i didnt wanna be there when the flames blew out the sides of his head.....hehe
Shocker
Ricky's mister top secret over here!! : gay.
Coolwhip
Vendor
no secrets, you just fail to listen
Shocker
Coolwhip wrote: no secrets, you just fail to listen
BS! I see no info in this thread about it, its most likely else where... I'm too lazy too look.....
Coolwhip
Vendor
He knows
Coolwhip
Vendor
the coolwhip blog tells all.
Coolwhip
Vendor
Shocker
you blow out some rings eh?
I still got that spare rb25 block I need to get rid of, name the price and shes yours!
Mistaken
Car: 93 240sx Coupe
Hey i noticed you are running one of the Turbonetics GTK's .... how did you like it? Any noticeable differences over a Garret Ball Bearing?
twofortyridaS13
Car: 240 93 HATCH SE
^^^I was thinking the same. Everyone was always saying go garret bb, gtk's suck and are more laggy blah blah.
Coolwhip
Vendor
Began tearing apart the motor...
Head looked fine...
Marking on the cylinder wall, no scoring though...
Block had a messy mhg with copper spray all over the place...
Coolwhip
Vendor
Mistaken wrote:Hey i noticed you are running one of the Turbonetics GTK's .... how did you like it? Any noticeable differences over a Garret Ball Bearing?
I can't really say or compare since I have yet to run this GTK on a 100% running motor.
Shocker
it looks like the HG was leaking on the #1 cylinder.. unless that brown is just oil on the head....
Coolwhip
Vendor
most likely its the oil from the head / copper crap all over the place.
All but the #5 cylinder had 160ish PSI compression while #5 only had 60.
Leak down test showed no signs of leaking through the rings or the valves of any sort.
Shocker
take the head to a shop to get the ports checked for leaks, you can eliminate one item there.
Coolwhip
Vendor
yea, thats the plan. Other than that an OEM headgasket is going down since this motor will only be seeing 20+psi of boost.
hmm
