KYOTE »
https://forums.nicoclub.com/kyote-u243580.html
Wed Feb 25, 2015 11:23 pm
Hey $$$ that is a funny coincidence considering its the same problems, at the same time, with the same cars. I have actually ruled out the wheel bearings with cupped tires due to the fact that the wheel bearings were repacked not to long ago and the whomp whomp whomp sound i hear is muffled when i drive on snow hence, its a tire issue. An update on the check engine light, it ended up being the MAF from when i ran the car without it plugged in. I had it turned off by o'reilly and the light has stayed off. I got the ball joints and control arms with bushings replaced and still have a clunking sound happening so im going to get inner and outter tie rods replaced and rack and pinion re greased due to the fact that they are leaking. With all that aside, my electrical issues are back. It started when i was refilling the transmission fluid and the A/T oil temp, Air bag, and O/D light all started flashing again. I went back to the main battery wire going to the fuse/relay box on the passenger side of the engine bay to see that the wires were starting to turn black and burning!! I cleaned them off thoroughly and resealed them hoping it would be the fix. I also saw that the yellow wire running off the main battery connection had a 25 fuse in it. I'm almost sure theres supposed to be a 20 amp fuse there so i switched that out as well. Since then i have not had any lights show up on the dash, rather, ive had 2 instances where parts of the dash would not light up at all. One time the whole right side of the dash (rpm gauge and coolant temp) wouldn't light up for about 1 min, then it turned on and hasn't acted up since. The second time was today where twice the mileage reader wasn't lighting up until a min of driving, then of course, it turned back on. I checked the wires to still see them burning. While nothing is shutting down, i'm worried i have a huge electrical issue on my hands. I can't find anyone else on nico reporting this problem so i feel like its not common. My guesses are that there is possibly a wire rub somewhere, a short in the system, the fuse size is still wrong, or a ECU issue. Either way, i feel like if i let it keep running like this, ill have a even bigger problem on my hands. I want let everyone know that when i say main battery connection, i'm talking about the set of wires that run to the right fuse/relay box, not the main battery connection on the battery, id love to post some pics but sadly i don't know how to do that. If anyone has any advice on the issue or wants to tell me how i can post some pics that would be fantastic, thanks.
