I have 8.5:1 compression. I'm not sure why I'm getting a big difference in numbers compared to most turbo ka people that run past 15 psi with a t04e compressor. My plan of attack is to check compression of each cylinder and then I will go from there. I also have a used turbo but I wouldnt know if turbo's can just stop flowing as much air over time. Anyone know?I'm thinking of going with a bigger turbo this summer. Prolly a Precision SC61.02_silver_wagon wrote:What CR are you pistons? Not to be rude or anything but I am looking at a similar setup and I thought a KA@17psi on a T04E 60 Trim would have more than 310 rwhp and 316 ft/lbs of torque. I am looking at the Precision SC60 60 Trim .63 A/R Stage 3 wheel, turbine side. What do you guys think for full spool by 3500-3800 and 350whp@15psi with 9.0(or a little higher) compression ratio? Its rated at 580hp.
Phax wrote:315's?!? I know single turbo Supra guys who aren't even running rear tires that wide. What's the point of going for such a huge contact patch?
andrave wrote:I don't understand how that could be, since its obviously a wider area contacting the pavement.
JPRempe wrote:The tire contact patch area does not go up or down when switching to wider or narrower wheels/tires Changing width only changes the orientation of the contact patch...NOT IT'S SIZE !
Structure240sx wrote:so if i get 225's of the same tire i would jsut as much traction as my 255's?
