that sound was tires spinning and hitting the rev limiter by accident in 1st gear.fiznat wrote:is that cluck cluck sorta sound tires spinning, the bov, or compressor surge? you can hear it the best in the very last part of the vid when the camerman is outside of the car... nice vid, but the car just doesnt sound right to me...
viscous lsd and MT ET drags at 14 psi. I ran it 4 times. 1st one was 13.1, 2nd one was a 16.7 cuz I let off halfway through the track cuz I was spinning the slicks because of too high of tire pressure, the 3rd was a 13.0 and the 4th was a 13.2. I could have definitely hit the 12s if I had a lil more practice and a better 60 ft. I got 4 runs in and it took 6 hrs to get those 4 runs in. The line was horrible and people were always breaking down. When I usually go, I get like 8 or 9 runs in. But this was the first time with my turbo ka at the track.deezlins wrote:nice, what kinda tires were you runnin? lsd?
my autometer egt kit came with the boss. All I did was drilled it where I wanted(the size of drill was listed in the instructions-basically a little smaller than the outside diameter of the boss) and took the manifold to an exhaust shop and had it welded oncanadians14 wrote:sorry i meant boss ... by that i mean a thicker piece of metal sticking out of the headers that can be tapped for an EGT... sorry i'm new with this stuff
klattr1 wrote:my EGT's seem right on with what alot of other turbo ka owners have at full boost in like 4th gear(17 psi) with Jim Wolf timing maps.Does it seem too high to you?
Structure240sx wrote:phax- in the other post i didnt realize ur egt was after the turbo. that seems extremely high to me. mine is an inch away from the head in cylinder #4 and got up to 1450-1500 when i was at 125+mph and 8psi thats the hottest they get.
All I am saying is that the exhaust temps are not above 1600 degrees. Its somewhere between 1400 and 1600 degrees F. I'll check it soon. But the higher exh. temps are due to Jim Wolf's retarded timing. My air fuel ratios are now finally solid.Phax wrote:Do you think that having the exhaust manifold, elbow and downpipe ceramic coated would cause higher exhaust temps to be registered?
klattr1 wrote:call me crazy but nobody's a perfect driver.
