LSDrift »
https://forums.nicoclub.com/lsdrift-u39769.html
Sun Jul 10, 2011 11:51 am
Just wanted to post an update to this thread and perhaps put more questions to rest. I just finished up and started driving my swap about two weeks ago and here's the story:
S14 radiator, pure distilled water(until winter starts coming around), FAL 412 Pullers.
Now, what I see, as I'm driving around town in 90 degree heat, stop and go for a couple hours even, no overheating problems whatsoever. Take it to the highway, cruising at 75-80 mph and then come off the highway and about 30 seconds back into low rpm driving it get's hot. Doesn't go clear into overheat mode but the stock dash gauge almost hits the top marking before it is in the over heat range. It will climb up to that point and then about 30 seconds later cool back down to operating temp like clockwork. Also, if on the highway I hit a pass or any significant hill(common anywhere in the area of Montana I'm from) I can watch the temperature gauge slowly move up if I have the turbo at -10inHg or more boost for extended periods of time.
To give more details, I need to flush the system as there is ton's of crap in the radiator even after filling and emptying twice already, and I also plan on trying some water wetter just to see how well it might work. Also I still have the AC condenser in place for potential future use and a FMIC that fills the entire space of the front bumper opening.
Bottom line is, I'm probably going to have to see about using the Koyo I have and perhaps a custom smaller AC condenser made up if possible. And then as many others are doing on here, use a clutch fan when time allows for some cutting and fab work.
