I agree. From my experience/data logging, I was pretty much maxing my MAF and stock injectors at 8-9 PSI of boost. I could increase fuel pressure a little and squeeze more from the injectors but the MAF needs to be addressed. Maybe a simple offset of the output voltage would do the trick. Still, without upgrading both components you will be pushing it to break maybe 10 psi.Carl H wrote:you'll run out of fuel and maf before you run out of block strength.
On one run at 8 psi of boost...6725RPM (2nd gear) / MAF= 4.94volts / LH & RH injectors at 92% duty cycle @ 97 mph, wide open throttle
Not much more to extract from these stock parts.
Modified by qsiguy at 12:41 AM 3/5/2009
