I'm not noticing any detonation but that doesn't mean it isn't happening. I've got water injection just in case. I'm going to be pulling the plugs to replace them with NGK Iridiums so I'll post up some pics for all to see.craigztoyz wrote:Cool Videos that you posted on there. Some great video links off it too, 1 of slims Z for instance. Are you getting detenation? are you running a led knock sensor monitor it? Had one on my GN, was useful
My guess is that it's putting out over 460 hp. The car feels so much faster than before. The turbo I'm running has a huge turbine so I think it is making more power than I originally anticipated.PanzerAce wrote:Cool. Any idea how much whp you're putting down?
I think I can get by on 10 psi with higher fuel psi and an auxiliary inline fuel pump. Plus, I've got the methanol injection to help out. The hardest thing is to not to be greedy with the boost. LOL.elwesso wrote:do you think you could see 10lbs with bigger injectors? That would be sweet!
I don't know. Here's my dilemma: A lot of people say that you need to lower compression and use forged pistons to run any decent boost. But there are plenty of stock 4 bangers running over 12 psi and have no problems as long as the tuning is correct.elwesso wrote:are you eventually going to decompress the engine a little bit so you can actually start USING that huge-azz turbo???!
i was more thinking about the prospect of making stupid power, like 15-20lbs..sijoko wrote:
So, if the VH45DE is such a strong engine, why can't we run 12 psi with the proper tune? Do we even need to decompress?
Now that is stupid power.....LOL. Depending on the turbo, you are going to be making upwards of 600 hp at 15 psi. Even if the stock engine can handle it, the rest of the drivetrain would probably give up the ghost. The car is too heavy for that kinda of power on the stock diff, driveshaft and transmission.elwesso wrote:
I'm curious as to how many stock non-turbo 4 bangers such as an SR20DE can handle 15-20 psi.Carl H wrote:again all in the tune.
Today, I was merging onto the highway and punched it with the car in 2nd gear and rode it out to around 80 mph. It was great and then I thought to myself, " Imagine how much faster this car could be if it weighed in at 3500 lbs instead of the current 4000+ lbs." Of course, I could just turn up the boost but then I begin to tread on thin ice.
Anyway, I'm hoping that somebody else will reach the limits of the stock block. I can't afford an engine rebuild at this time.
Interesting that you brought up rod bolt failure as the most likely scenario. That should only happen with rpms and not from cylinder pressure i.e. more boost.Carl H wrote:in my experience thus far its not the rods that are weak but rather the rod bolts.pistons are the 'weak link' in the turbo chain followed close by the rod bolts; I've not seen a rod just break and go flying thru the block (not that it doesnt happen) but rather you see rod bolt failure which causes the catastrophic damage.
