Q45 sun visor repair
Q451990
This thread should definately become an "article" after you're done. I can't imagine a more complete discussion of sun visors!
Heath
tangalora
Car: 1990 Q45
The two Q45 sunvisor Technical Service Bulletins are invaluable!
The first TSB (ITB90-036 Nov. 29, 1990) showed the exact Q45 sunvisor step-by-step removal procedure (which is different than what I posted above in some respects).
The second TSB (ITB94-006 Jan. 20, 1994) explained the removal procedure for the sunvisor vanity mirror and lighting assembly (leaving the sunvisor attached to the Q45).
The good news is the combination of the two sunvisor TSBs gave me an idea for a better fix than what has been previously noted; when I get a chance, I'll try it out (perhaps this weekend if I can find the time between gift shopping) and (of course) document every step with an explanation & a photo so folks in the future can follow our best path.
One question about the cryptic (to me) abbreviations used in the TSBs.
Under "Claims Information", the first TSB notes:
  • OPERATION: Replace both sunvisors
  • OP CODE: VA22AA
  • PNC: 96400
  • CS: 3G
  • CT: 34
  • FRT: 1.0 hour
The second TSB uses similar abbreviations:
  • OPERATION: Repair Wiring Harness
  • OP CODE: RA16AA
  • PNC: 24160
  • CS: ZE
  • CT: 61
  • FRT: S/T (straight time)
Do these cryptic (to me) abbreviations mean anything to you?
Alora Duncan
Q451990
I believe those codes refer to how the dealership gets paid for the work under warranty claims.
Heath
tangalora
Car: 1990 Q45
Sorry to keep you waiting.
During the Christmas vacation, I finally got back to repairing the driver side 1990 Q45 defective sunvisor post attachment.
Expressly so others can save time & effort, I snapped a series of photos showing the Q45 sunvisor repair steps (& some tricks I learned on the way).
The first trick I gleaned from the TSBs was to remove the mirror assembly. While not required for the Q45 sunvisor defective post repair, removing the sunvisor mirror assembly has advantages, as will be shown later.
tangalora
Car: 1990 Q45
Pry off the two opaque white light covers using the notch provided in the Q45 sunvisor mirror assembly expressly for that purpose.
I happened to use a letter opener because it was small enough to fit in the 1 millimeter wide notch without damaging the white plastic light covers.
tangalora
Car: 1990 Q45
Then, as explained in the Q45 ITB94-006 TSB titled "Sunvisor Vanity Mirror Repairs", remove (and save!) the four white pieces of tape covering the mirror mounting bolts (I pried them off using the letter opener again).
Then remove the four vanity mirror attachment bolts using a #1 phillips screwdriver.
tangalora
Car: 1990 Q45
Once the four #1 phillips bolts are removed, pull the vanity mirror assembly away from the sunvisor assembly.
tangalora
Car: 1990 Q45
Close the vanity mirror cover ...
tangalora
Car: 1990 Q45
Flip the vanity mirror to expose the wires.
tangalora
Car: 1990 Q45
Locate the vanity mirror assembly two-pin wiring harness connector ...
tangalora
Car: 1990 Q45
And, (optionally) disconnect it ...
tangalora
Car: 1990 Q45
Make a note of the path the wires take:
  1. First, the wires pass through the sunvisor body (contrary to what is shown in TSB ITB90-036 Nov. 29, 1990 titled "Q45 Sunvisor Misaligned")
  2. Then the wires enter the sunvisor post elbow (from the outside, in)
  3. Then, after exiting the sunvisor post, the wires pass through the sunvisor pivot joint
  4. Last, they pass through a washer, a spring, and the defective so-called "press-on nut") until they terminate at the white, two-pronged, sunvisor connector[/list=1]
tangalora
Car: 1990 Q45
Close to the black vanity mirror connector, cut the two wires at DIFFERENT points.
Ofsetting the cut point eliminates the chance of re-connecting the wires backward; and this offset technique also minimizes any chance of chafing wires shorting together in the future.
tangalora
Car: 1990 Q45
Pull the two vanity-mirror wires out of the sunvisor & sunvisor post elbow & remove the sunvisor pivot, washer, spring, & defective press-on nut.
Inspect the naked sunvisor aluminum post for the ability to take threads.
tangalora
Car: 1990 Q45
Place a drop of olive oil on the damaged aluminum Q45 sunvisor post and carefully begin threading with an 8mm by 1.25 millimeters per inch threaded die ...
tangalora
Car: 1990 Q45
Keep cutting until (at least) 6 mm of threads exist (about 1/4 inch) or until the soft aluminum visor post protrudes from the end of the cutting die.
tangalora
Car: 1990 Q45
Continually apply oil & re-work the threads, back & forth, until you have at least 6 or 7 threads cut into the aluminum sunvisor post.
Then remove the cutting die & blow the stud clean of olive oil & aluminum debris.
tangalora
Car: 1990 Q45
Gently clean the shaft & closely inspect the new 8mm x 1.25 mm/mm cut (these 6 or 7 threads will soon be holding back a huge amount of coil-spring tensional forces).
tangalora
Car: 1990 Q45
Add a new nylon-capped 8 x 1.25 mm steel lock nut when you re-assemble the parts & re-thread the wires (I chose to leave the defective press-on nut on the vanity mirror wires, but you may wish to discard it).
Code: Select all
Note: As the unsprung coil spring alone is longer than the available stud, with the addition of the new lock nut, you'll almost certainly need to effectively extend the shaft length any way you can.
tangalora
Car: 1990 Q45
I tried using clamps, pliars, vise grips, etc., but I could NOT compress the coil spring enough to get the threads on the nut to bit onto the shaft.
Therefore, I finally followed the recommendations in this NICO forum by sanding down the pivot point landing tower by about 5 mm, effectively halfing the tower size and adding the desired 5 mm to the effective shaft length of the sunvisor attachment stud.
Having no sanding or grinding equipment available, luckily I found that the soft plastic pivot point landing collar was surprisingly soft. Only a few minutes rubbing the collar back and forth against a piece of sandpaper (left over from when they refloored my kitchen) did the trick.
tangalora
Car: 1990 Q45
I stopped sanding when the unsprung coil springjust barely covered the protruded shaft.
tangalora
Car: 1990 Q45
Shortening the collar (effectively lengthening the shaft)allowed me to finally get the nut on fully.
Note the nut is screwed on until the shaft just hits the nylon locking material.
tangalora
Car: 1990 Q45
Strip about 3 or 4 mm of bare copper wire and slip heat shrink tubing over each end BEFORE soldering any wires back together.
Note the joints do not overlap (thereby better protecting against shorts later on).
Also note the wires were cut in the low stress area BEHIND the mirror (instead of in the higher stress area above the roofline as initially considered).
tangalora
Car: 1990 Q45
With the heat shrink tubing slipped on, twist the copper wires together, before soldering them.
tangalora
Car: 1990 Q45
Cover the staggered solder joints with the heat-shrinktubing; and then warm with an open flame to shrink.
tangalora
Car: 1990 Q45
At this point, the repair has been completed.
Re-assembly should be the reverse of the dis-assembly procedure.
By the way, does anyone know why, all of a sudden, after I used the "CODE" buttons, the web page no longer fits the text to the window?
I've been forced to enter copius line returns just to be able to see what I've written.
I think there is a bug in how those code tags are interpreted.
Can someone fix it (it makes it very hard to read).
tangalora
Car: 1990 Q45
This weekend, weather permitting, I plan on (finally) putting the driver-side sunvisor back on the Q ... so I'll document the R&R procedure as best I can so future Q'bies can benefit from the culmination of all your advice on this forum.
Q451990
You should get a job writing TSBs or service manuals! I'm going to go back and print all of this for my file in case we ever loose the server. Great stuff!
Heath
tangalora
Car: 1990 Q45
Thanks for the kind words.
I am (slowly) getting better at using this forum and at posting pictures which try to convey the desired point. I've experimented with a variety of backgrounds, for example, from my frost-covered tabletop to the bland white background of the TSB itself.
I also experimented with the SIZE of the pictues (noting that the original size of my photos is 4 or 5 mbytes). I hate to shrink the photos (lose data); but it must be done for the forum to accept the shots. Also I've experimented with colors and fonts and sizes of text and wordings, etc., to try to convey the best shortest description of the component of the problem that threw me when I did the task.
It was too cold today (for me, a warm blooded DIY) to work outside. Hopefully tomorrow (Sunday) I can get to the visor (and, oh, the brake light sensor just went on so I can feel an article on replacing brake pads coming on :) ...
Alora
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You can post larger pictures in the member's rides sections.
Perhaps we need one for projects also like Wes's and Tangalora's, and some of Daedalus' old ones?
