I found that guy about a year ago. I downloaded some info off his web site. It looks like a prety good deal.
The brackets sold on eBay, recently, for under $100. A set of 300ZX Rotors would cost less than $200. That makes the 12.5" rotor upgrade around $300.00 (not including labor). Not a bad deal, if you ask me.. Description: This procedure contains assembly process and required tooling to perform 12.5” Brake Conversion Kit installation
Disclaimer: The 12.5” Brake Conversion kit is not intended for street use. Use this product at your own risk.
Required Tooling and Parts1) Lug Wrench2) 19 mm Combination Wrench3) Metric Socket Set4) 12 mm Combination Wrench5) Sheet Metal Cutters6) Torque Wrench7) LocTiteâ 2428) 12.5 Inch Brake Rotorsa. Mitsubushi 3000 GT VR-4 1994-1998 (Not Included)
Material List:Part Number Quantity Description1 2 Caliper Mounting Brackets2 4 M12x1.25x30 Grade 8 Hex Head Bolts3 4 M12x1.25 Nuts4 12 12 mm I.D. Washers
Installation Procedure:
I. Jack up cara. Apply Emergency brake.b. Jack up car.c. Ensure car is on level surface and securely supported with jack stands before continuing.
II. Remove Front Wheel
III. Caliper and Rotor Assembly Removal
a. Using 12mm wrench, remove two bolts holding brake line support bracket to rear of spindle.b. Using 19mm combination or socket wrench, remove the caliper mounting bolts.c. Slide brake caliper off rotor and set aside.i. Note: Be careful not to allow brake caliper to hang by the brake line.d. Pull brake rotor off of wheel hub.e. Using Sheet metal cutters, remove brake rotor heat shield.i. The spindle following heat shield removal is shown in figure 1.
FIGURE 1
IV. Bracket Installationa. Remove the original flat washers from stock caliper mounting bolts.b. Replace with washers supplied in kit.i. Note: 1 washer per bolt.c. Slide original caliper mounting bolts thru caliper mounting bracket as shown in figure 2.
FIGURE 2
d. Install caliper mounting bracket into spindle.i. Apply Loctiteâ 242 to bolt threads.e. Secure bracket using 2 flat washers and 2 - 12 mm nuts.f. Tighten caliper bracket mounting bolts to 72-87 ft-lbs.g. See figure 3 for installed bracket.
FIGURE 3
V. Caliper and Rotor Assembly Installationa. Slide new 12.5 inch rotor onto wheel hub. See Figure 4.
FIGURE 4
b. Slide brake caliper onto rotori. Apply Loctite 242 to bolt threads.ii. Mount to caliper bracket using 2 - M12x1.25x30 bolts and washers. See Figure 5.
FIGURE 5
c. Tighten caliper mounting bolts to 72-87 ft-lbs.d. Using 12mm wrench and original mounting hardware, re-attach brake line support bracket to rear of spindle.i. Note: You will have to slightly bend steel brake line between caliper and brake line support bracket. See Figure 6.
FIGURE 6
VI. Re-mount Wheel.VII. Repeat Steps I – V for Second Wheel.
Contact Information:E-mail
[email protected] if you have questions regarding the installation procedure.
I am still going to upgrade to the aluminum 300ZX calipers, but want to get a set under $200, if I can. Then, if I want more later, I can upgrade again and not feel bad about dropping too much money along the way
