squeefoo wrote:Hitman - I have 300ZX AL calipers on w/ stock rim. But the calipers stick out a little under .5" Rim diameter is of course 15" on mine. Unless you're on the brakes a lot AL isn't a problem, heat soak wise, (not for auto crossing). I tossed my kid and my ex on the floor in a panic stop in Chicago a few weeks ago, (didn't have their belts on yet) 70 - 0 in what seemed like microseconds, I think better than stock.
Did you have to modify the calipers, or hubs, to make them fit?
I would think the DOT4 fluid should help, wit hthe heat soak issue.
I want to upgrade to the 300ZX, front and rear.
Does anybody know if the rears will work? I have a bad caliper on the driver's rear, and it is eating up pads rather quick.
