JerseyS14 »
https://forums.nicoclub.com/jerseys14-u132657.html
Sat Aug 22, 2009 5:58 am
I had a push start on my 1st gen altima and i'm sure it's about the same kind of work to do it on an S13/S14... I was thinking of doing it but i have to buy another switch since i gave my old switch to my friend...
I used an S2000 push starter switch.. In the switch it has i believe four pins.. You need to use the a computer's floppy disk (A:) power connector (or something similar) which i feel was the easiest thing to fit. BUT the S2000 only needs to use 3 pins out of the four... (ground, ignition, and constant 12v) I know i'm confusing you with the pin and computer stuff without pictures.... But i used 2 relays (one on the ignition and on from battery (or any live wire if you're splicing into another wire)... and this is how it came out
Keep in mind i removed the need for a key AND had to cut my steering wheel lock off in order for this to work. On the other side of the steering wheel by the dash i had installed two toggle switches which would feed the switch (ignition and 12v)... so without the 2 switches up, you can't start the car... AND of course you would need a car alarm because then anyone can just run up in there and pop those two switches on.. and gone in 10 seconds... (not 60)...
Here's another pic from far..
