Darius wrote:I thought the same thing. The first thing I noticed was how clearly the cross-hatch in the bores can be seen.
The head gasket always looks nasty but that's what happens with the organic gaskets. What kind of head gasket are you going to put on there when you reassemble it? And why exactly did you disassemble it in the first place? Are you putting forged rods and pistons in it?
One other thing... is there any assembly lube on the cam journals?? They look dry as hell. Don't even think about trying to start that engine without smothering those things with assembly lube.
Darius is right, pour oil over the cams, or cake some assembly lube on them before you put the covers back on and fire it up. The lobes look to be in great shape though, there's just no oil on them because its been sitting for so long.
Also, it may look nasty, but the stock headgaskets make a mess like that after being smushed between the block and head for so many years. All of the carbon and crap in there may look nasty, but it also assures you that the motor has likely never seen above stock HP or anything other than factory electronics. Thats a GOOD thing!
I think you're motors overall in great shape. If you're not shooting for 500+ hp, get yourself a stock gasket set, and drop your head off at a machine shop for a good clean and resurface.
Good luck!-Max
